Berg Cup (rally Car)
they are golf mk2 gti rear brakes.
I just added the strengthening bars where I needed them to be as I could see from my previous beams where I had bent them.
  • Replies 410
  • Views 102.3k
  • cheers should be ready with in the next month now.
  • ye ticks over lovely and it revs so clean I'm really happy with it i was having thoughts that i would have to but mbe or some managment for it after it run last time but the way forward is late spec c
with the rear axel do you just need pretty much everything off the back axel?
sorry mate dont quite get your question.
to do a rear disk conversion to you take everything of a mk2 golf 16v?
is the handbrake cable a home made job?
yep everything off the golf mk2 gti mine came of an 8v. I havnt looked at the piping or the handbrake bet
but will let you know.
If you have a choice, use the calipers from a late mk2 or mk3. They have internal return springs and don't seize, where as the ones in the pictures are renown for going solid.
ok will look out for some but these wher sayt out side in the rain not used for 4 years and hadnt seized so I just overhauld these and they are moving nice.
Mk4 Golf calipers are similar/the same mounting I think? But aluminium...
nice job looks good!
how do the rear callipers and disks sit on the beam is there any custom mounting or?
mk4s fit straight on to the mk2 carriers, I'm unsure if the mk4 carriers fit straight on as well tho? you can get braided hoses for the rears only from tsr performance... deffo worth the upgrade...
as for fitting, i believe you just need mk2 16v stub axles, wheel bearings of a mk2 16v too and a rocco 16v handy b cable (not sure if you can use these on the polo or if you have to modify your exisiting ones?)
Mk4 Golf Kit Car Rear Beam:
Pics may be of some use- be awesome to see this once it's together :-D
Today I have been making my light weight perspex windows.
here is a quater light
the rear side windows
the rear window
and a door assembled to see what it will look like.
I'm happy with how they have turned out
they look pretty cool! how long did it take to make the driver side window? was it difficult?
they look BLOODY good to me
I was given the sliding kit so all I had to do was cut the window to size drill and bolt. but to make all the took from 11am till 6.30 pm with a lunch break.
Are they really acrylic or are they polycarbonate?
They are whatever it states in the blue book that I need for rallying. thats what I orderd anyway.
my vernier pulleys turned up today
they are dblias dynamic for my AFH 16v engine.
here is a pic
Heg ...... as the front windows will no longer go down, did you consider making them one piece and doing away with the quarter light altogether ? if so why did you not do it ? Cheers David
loving this thread ! great read and quite interesting
yes i did think of it and wanted to do it but I would have had to buy another sheet to get them in and didnt want to so the quater lights fitted in off cuts.
almost as interesting as eastenders...... :lol:
Edited by mathew
Proper budget racing approach ............. love it.
loving it,cant wait to see it finished...anyone know where to buy a fix in roll cage for a mk3 polo coupe?
over the last week I've been flat out working on the car I've finished the seam
welding and strengthening to the shell also put the seat bars in to msa spec and made
my roll cage go up to the stut tops.
As I have a bolt in cage that is worth so much these days I didnt want to weld anything
to it so I came up with this design used from some parts of an old roll cage I had.
so here are some pics.
the shell is going to be sandblasted on sunday weather permitting and then she will
be paited in undercoat
