m45 on a polo 16v
I want that inlet system though!1 what is that from?
  • Replies 35
  • Views 5k
You'd prob. be cheaper picking up a G40 engine and putting that in....at least in the long run....at least it is designed to run boost.
AFH is the tall Polo block, same height as the ABU/AEA/AEE right?
Then you can use 144mm rods. These are available from Scat at around 320-330 USD (600+++ hp), or you can use Audi S2/4/6/RS2 rods. These have 20mm little end so custom pistons is needed. You can find custom JE pistons in the states from around 600/620 usd incl postage
you cant use those in the polo engines because they dont have the hole in the centre which feeds the oil to the gudgeon pin from the big end
that isn't a polo gti engine, doesn't have the variable valve timing gear on the top, that intake looks like a cut-n-shut using a early mk2 golf intake manifold joined onto a lupo gti manifold, strange, has bosch inkectors too istead of the oe webber ones...
that supercharger looks like a sprintex to me but it's hard to tell, you wont get one of them for less than £2k
Edited by SkodaBoy
Do you really need that? G40's don't use it, 1,8T's dont use it, S2/4 dont use it........
With custom pistons with 20mm gudgeon pistons in place of the 18mm oem ones, there should be no need for them......
you are missing the point, it's got nothing to so with the size of the pin, it's about lubrication, without oil fed to the small end they would sieze within miniutes..... remember, the 1.8T, 2.0 etc etc has spray jets which squirt oil at the underside of the piston instead
Edited by SkodaBoy
Iv seen engines without the conrod feed that dont have piston squirters, they have a small funnel like hole in the little end to catch oil coming off the piston... which is coming through from the scraper ring or from windage and splash from the sump
I dont think the G40 rods are drilled? And the G40 defenitely does not have oil squirters. I think you also can order the scats riffle drilled
yeah, i've seen that too, but they dont have a fully floating piston like the vw engines do, and it's normally only on diesel engines where you have masses of oil residue on the bores
that i'm afraid i dont know, i've never worked on the inside of a G40, but i should imagine they are riffled drilled like the rest
not that hard to fit oil squirters from a S2/S4 og 1W though
pop onto clubpolo and talk to Paul Bin, hes the lad with the 16v lupo with the m45, I'm assuming there pretty similar engines. if not I'm sure he will be able to give you some advice. his engine hasnt blown up or anything, runs perfectly, it made 171bhp on the RR the other week, the trick is to just not drive it like a dick all the time lol. if you cant find him on clubpolo his user name on night-riders.co.uk is paulbin.
hope that helps chap.
