Leaving heating off till car warms up
i donno if u guys do this but i dont, in the polo manual it says as soon as u start the engine drive off straight away, but not to take it over 3000rpm (i think) till its warmed up.
Yeah, that's only in the interests of the environment though, and nobody gives a shit about that.
  • Replies 44
  • Views 2.1k
i always let it warm up for 5 mins then dont take it over 3000k untill its upto temp properly.
I read that. It says something about the environment with it too, that leaving it running produces more fumes. Doesn't say which is best for the engine though
TBH, I don't see any difference in how long mine takes to warm up if I leave the heaters off, or use them straight from the off. I'll only put the fan on 2 though, because there's no point in blasting myself with freezing cold air when I first start off.
usually just start the car, put it to demist the screen on number 2, then jump out and crack out the de icer and scraper. usally when I've been all the way around the needle is starting to move and the inside is warmish.
with the audi, i turn on the engine, deice the windows if necessary, or let it run for a couple of minutes.
then the journey to work is done at no more than 3000rpm as i dont have that far to go and i always give the car a chance to warm up before caning it.
i just start the car, fans on full then go back in house and have a wank, then go back to car
To find its been stolen, you were so busy wanking you didn't notice.
I just drive off with the heaters on full, but i try keep the engine around the 2000rpm mark as i feel it helps the car warm up quicker, probably doesn't though.
to be honest I've never even thought about it!
sometimes i put them on sometimes i don't. never take the car over 3k till its warmed though.
sometimes i put them on sometimes i don't. never take the car over 1k till its warmed though.
suprising dan, thought you of all people would have done it!
And good practice with the low rpm till its warmed up, gives the oil a chance to reach that crucial temp.
1k! i meant 3k lol wouldnt even move hardly 1K lol
You said 3k lol
Someone is being funny :lol:
it is just you i have mine on when i get in altho i never seems to come on until i get home :lol:
you better have the heating on for me when i come up next weekend I'm not getting in a frozen polo lol
I leave the heating off until the engine temps rise a little, unless it's really cold/ misty in which case, for safety’s sake, I’ll turn it to hot. I always drive it gently until the engine is up to working temperature but the volume of the piston slap is a good indication of whether it's up to temperature or not :lol: In any Mk3 or earlier, leaving the heater on 'cold' will help it warm up quicker as you're only circulating coolant in the block. It's not as relevant on later Polos as the heater is permanently rigged up to the pump/ block.
Starting your car and leaving it to idle doesn't do much for it in the long term....just drive off straight away as recommended.
Since getting the Ibiza I just let the CC do what ever it wants. Still being a TDI with a big FMIC it stays cool for a while. As for the camper that has it's heating stuck on hot so I can't do anything. (The G is wraped up warm for winter).
Edited by Depresion
i dont have time for these routines, i scrape the ice off, drive away with the window down, stop halfway up the hill scrape windscreen again and then its fine. fucking cold, but the cars ok.
i do that to, no point in blowing cold air IN the car :p
pah! you can borrow my VW Jacket I keep in the car.
Edited by panda
Walk out the door .. walk to car open car door get ice scapper out, start car heating full blast shut the door spend 5 minz scrapping the bloody ice off the windows by the time iv finished its slighty warm in the car soon as i get to the end of meh road hot airs finally starts to make its course upto me :)
i do
No point in turning the heater on before the engine warms up, it just blows cold air into the cabin :S
