16v
What revs does the limiter kick in then, never really tried to reach it.
  • Replies 44
  • Views 4.8k
even with 14's ull have clearance issues on the sump ! :-(
mines on 16's with 75mm drop all round and I've had quite a few near misses regarding the sump stayin attached to the car :oops:
get some fat as fook 15's n strecth some sexy rubber over em :unibrow:
unless you count drivin over bricks lying in the middle of the road close i doubt it... subframe and cat hits the ground before anything else
Jez's valver was scraping the floor at all times and the sump is not a big issue unless you hit something lying in the road
Valvers aint all that quick tbh, don't see what all the fuss is about.
No, they aren't that quick - but they are pretty damn impressive for a 10 year old N/A 1.4! Plus they are so easily tuneable!
my thoughts exactly 8-)
Think its about 7100? never really go past 6750 when gunning it just saps the power after that
so am i rite in guessin that bigger wheels & tyres (well a bigger circumfrence) make you faster? i.e. a 16" wheel with the same profile tyres and at the same RPM as a 13" wheel should make for a higher top speed seeing as you're travelling that little bit further per revolution. or am i talkin sh*te? lol. :smirk:
When i took the 17s off mine and put 15s on it, the difference was unbelievable..
how u fit 17's, i dont kno? i'm rubbin on full lock wid 16's.. and so whats wid the small wheel 'faze'? strictly jus a 'euro look thing'? btw what was the diffrence?
in English ?
Edited by Foxie
no you are right...that way you can increase the maximum permissible speed with the same rev limit
but the engine wont have enough torque to manage any extra speed
how in gods graces did you manage to fit seventeen inch alloy wheels inside your arches? i am currently running sexteen inch alloys and already i am having trouble with the outer tyre wall's rubbing the inner arches on complete lock. lol. just f*ckin wid you. :oops: my bad
and thanks for clearing that up @ 16vTej
And whilst you'll be able to go faster (top speed) you will loose acceleration, so the car at legal speeds will feel a lot slower! I've never been near the limiter in 5th! I'll save that for my eurotrip next year! lol.
erm.. how/why will you lose you're acceleration? you aint messing with the gearing or ratio's or anything, just the overall wheel diameter. so in theory should the wheels not still spin at the same rate just making you travel further??
acceleration will be slower... look up some physics explaining torque and especially moments and it'll all be clear
'i hit near the limiter in 5th all the time on my private road to no-rice. It gets boring. =]
Oh and the limiter seems to be around 6800
Simply put, you ARE changing the ratios. if the wheel diameter is greater, then the circumference will be greater (that's obvious I hope).
So for each revolution of the engine ->gearbox ->wheel, there is a higher overall ratio. (that's quite obvious too I hope)
Now if you make the difference too big, i.e. a car usually on 13" running on 17". Your overall ratio could have changed so much that first gear is now got the same ratio as second gear did at the wheels (it won't be quite that bad, but this is just to get the idea across). And you should know from experience of driving, or even riding a geared bike that the higher the gear the harder it is(more torque required) to get up to speed.
Hope that's explained it simply enough.
oh i see, i see. cheers :thumbsup:
i have a mk5 1.4 16v 75bhp.
i got to 105 and got bored of waitin!
how on earth do i get to at least 110 or 120?!
Oh and by the way, i have standard 14 inch alloys
i think everyone is talkin about the mk4 1.4 16v (100hp)
oh :(
how can i boost the power of mine?
i know theres alot of difference between the two engines as they have different cams etc
