going to view a polo gti
is there anything that doesnt need checking on a gti. i don't think i'd ever bother with one seem like too much hassle.
its all part of the charm.
  • Replies 32
  • Views 2.3k
I agree. I don't care how many problems it has, I still love it to bits. Imo the best Polo ever made in terms of all round ability
you dammmmmm right 8-):lol:
wheels - £200ish
door handles peeling - £30ish
rear washer leaks. hard to tell without taking things apart - £not much - 10's
gearbox - £lots - 100's
bootlight. may need new switch. might be due to rear washer - £10ish
coolant temp sensor. look for the temp guage being strange/ switching between norm and zero while driving. over reving - £15ish
remember it will need a major service at 40,000 - £350ish
i needed all new pads and disks - £350
hope that makes sense. good luck.
I have this problem! how do i fix it lol tried replacing the plug in the boot but still doesnt work! didnt know it was a common problem
wheels - £200ish
its really easy:
just take off the inside boot panel. its just two screws and a few clips.
then remove the locking mechanism. just two bolts.
pull out the old switch and replace with new. if you buy the part first it will be very obvious what bit you need to pull out.
then reverse of course.
its costs about £10 and takes about 10 minutes to do. i don't know if it is "common", but it happened to me.
while the panel is off you can check to see if there's a metal clip round the washer pipe where it joins the pump...
Edited by one_must_fall
Well my dad bought a new plug from vw, the one the size of your small finger nail with 3 wires sticking out of it, and replaced it and it still doesnt work. So is the plug and switch different things?
i've drawn a diagram. its definitely a "switch" not a "plug":
http://www.btinternet.com/~chris.hocking/AIR/switch.bmp
ok thanks mate will have another look at it
