mk4 valver performance
so the box will last longer if you dont rag the fook out of it in each gear and redline it?
surely chaning gears at the correct time like before 2-k revs is fine :?
  • Replies 31
  • Views 1.8k
I'd say 2.5k -3k is about right to change..that's just what I think though
I've had a 1.2 corsa for 2 years now, i bought it for £220 and it hadnt been looked after at all, breather pipes had poo clogging them lol, and no oil etc. i tidied it up, and have looked after it ever since, I've never replaced a part. its currently done 150000 miles. i know its not a polo, but its still a car, and i reckon if you look after the car and dont give it the death 24/7 then any car should last, unless its a h reg french turbo hatchback lol.
can anyone on here say that their box went due to "toodling along" lol
if u go to halfords, and get a sunstip and a 5 inch exhaust it will give you 30bhp
Then we get the 1.0 Mk3 Polo I had which I got bored with using the clutch and used to drag it out of first and crash it into second when I was in a hurry. Clutched the other gears but seldom 1st into 2nd if I was going some.
I also hit the limiter from about 10 seconds after starting it, would slam it into 2nd at 70 to get some proper engine braking, dumped the clutch at the limiter almost all the time, generally gave it death.
And guess what? I replaced the head gasket at just over 60k which is quite a common time for them to go, and carried on giving it death until I sold it to a nice old man.
The Golf gets the same apart from there is no rev limiter and instead I hit 8000ish rpm from cold.
That's why old VWs are far better than modern ones!
Both gearboxes are fine! I thought the diff was on the way out in the Golf but I changed the oil and it's fine :lol:
yep mine has really started to whine :C
only a matter of time
