Any info on this G40 please, J142 WLS...
Its such an abomination......... why would someone do that to a G!!!
Adding a turbo would make the polo more petrol efficient, or that is what I am thinking the aim is. I know buying a 1.0 micra would save even more petrol but I still want to have fun, just not cost quite as much as it does.
I'd love to put a magnet clutch on the supercharger so I have still got the option use both chargers for full whack driving (Like a McLaren f1 I think), but run just on the turbo for long distance cruising where turbo-lag isn't a safety problem.
I would think a G supercharger will block back airflow when stationary (can anyone confirm), so all the compressed air should end up in the cylinders I would think.. There is already an oil feed and plenty of space and the MAP sensored ECU. I might even go for the 7.5:1 pistons if it works better than I think...
As there is no overlap on the cam it's going to be less of a horsepower drag having an exhaust-gas turbine in the exhaust tract than the supercharger dragging back the engine even at low throttle...
New thread d'you recon?
NealPEAL!
  • Replies 50
  • Views 5.4k
