PLEASE READ *BEFORE* POSTING
Recently I have noticed the same questions are being asked time and time again. People will reply to your post but the more it gets asked the less likely people are to reply to it because who wants to write out the same thing once a day?
First thing you should do is check in the FAQ section. Anything that is frequently asked is most likely to be covered in there. People are always adding to it to help make the guide better.
If it is not in the FAQ the second thing you should do is do a search. The search button is in the top right hand corner under Private Messages. If a topic has been covered before it should come up in the search.
If you do these and you see no result then feel free to post.
When you do post, please make sure you say what car it is!! No one can help you unless they know what car your on about!
If your asking about tyre sizes make sure you include the width and diameter of the wheel! Without these its hard to say what tyres will be suitable for your application!
Thanks.
  • Views 14.7k
