door mirror switch
Has anyone swapped over the door cards from a 6n0 mk4 to the 6n2 2001 door cards. I am trying but i may have a problem with the mirror switch, the wiring is different. What do think? I tried to use a mini drill to grind a bigger opening for the older original switch, but the bigger space needed has eaten into the space where the door handle goes. Will need to fit the newer type switch.
I have got the sales brochure for the 6n1 (1998) model,the one after mine, it has the newer type of switch, i have also got a haynes manual for the polo upto 1998 and i checked the wiring diagram upto 1998 and the wiring for the 1998 door mirror switch is the same as the 1996 polo (mine) so........ that should mean that there is a newer switch which will plug straight into my wiring connector, is this so, can you help me pleeeeeeeeeeze.
Sorry to be long winded, but its been drivin me mad.
I'm hoping some other crazy guys have done what i'm wanting to do.
Edited by happyknight
  • Views 611
