180bhp in a mk3 polo g40
Exactly Dan I must have done 60-70k in a G and used it in all weathers on all roads. A standard G40 is a fine thing and going back to one after a modded one was a joy. I've upped the power a bit on mine now but I drove it for at least 6 months standard and enjoyed it all. The one time my I cooked my breaks was when I first had a G and the pads were knackered and the fluid was probably years old. After that they've been fine, I thought I would miss the 256's but apart from my master cylinder being fecked they are actually ok.
G40 I drove had stock suspension and brakes.
I think thats the problem I have with any of your arguments. Just get your car on the road Tav and enjoy it and then if you dont like a part of your car improve it then. Doing all the mods before you get it on the road I think you will miss out on how good they can be from the factory. Or maybe I'm just getting old. :paranoid:
My car is on the road, I'm driving it daily.
Under GT power just now and it leaves a lot to be desired in the braking and cornering department. If I thought the standard G40 needed improving this is on a different level.
Edited by Tav
  • Replies 82
  • Views 4.7k
Lucky bast4rd I say.
I wouldn't turn a go in a sunny GTI-R down.
amen to that, my mate karl is running in his 500bhp one atm, looks to be a right beast!
cannot wait until the engine is bedded in!
Quinny lol in a straight line you should put on the end lol
The standard brakes lack bite, lack feel and you can easily over heat them without really abusing them. It was an issue when they were new and its more apparent now with modern cars to compare to. Just read some of the reviews I posted in the photo and video gallery.
256mm disks, G60 Calipers, 22mm master cylinder, good pads and fluid should see the brakes come in line with the straight line performance. Not an expensive upgrade and uses items available from other VAG cars...just required 14" wheels. For a road car that is as far as I would go.
Quinny those engine mods you listed are what I am looking at doing. Hopefully the GT inlet will drop the torque a little and make it more driveable.
I agree its how you use your brakes in the right conditions rather than the size of brakes which will be of more benefit.
Tav, i think you have your wire crossed. The G60's run 280mm discs, so i'm pretty sure you won't be able to run the G60 calipers with the Audi 256mm carriers without modification. If that was the case we would all be using Audi S2 twin pot calipers
haha proper side along thread going on sorry mods!
they are 4wd so cant be that bad? short chassis too, i imagine a bit of understeer sometimes but thought they are supposed to handle amazingly?
The Girling/Lucas 54 calipers I have are fitted to Mk2 Golf 16v's and G60 Corrado's...Corrado has a different carrier to accomodate the 280mm disk...or at least some I am told?
Edited by Tav
for the purpose of being on here i have a mk3 gt which i drive every day, and i also drive a nissan sunny um... GTI-R if you know what that is? thanks for the question, cheers rob
this aint a competition to see who's got the biggest nob. the point is how can you comment when you dont even drive one? such as half the people on this site.
personally i think the handling is ok. the brakes are ok too. nowt amazing but I've not had any problems. big nob there, starts giving the low down on how they aint upto the job. all I'm saying is GET a g40 drive one if YOUR not happy with the setup change it. i think its a waste of money to be honest for a daily driver. a track car or weekend toy fair do's.
so many people bang on when theyve never even been in one, you dont see me banging on about new gti's? mainly cos i dont give a fuck and secondly cos I've not been in one and have nothing to base my opinions on....
Edited by supercharged spaniel
tav you really are a pussy sometimes. i had 150 brake in my old g40 with standard brakes and only slightly uprated suspension. i really think you must have driven too many modern cars and been spoilt by the great brakes etc, cause if you think when you are driving it that its old and the brakes arent quite as good as newer cars you wont get into trouble.
i have only once come unstuck in mine and the brakes [stock] were more than up to it, they were more than powerful enough to lock up yokos on a bone dry road from about 100 down to 40 then locked. i dont know what all this talk of brake fade is.
as long as you dont try and compare g40s to a modern car you will be fine.
i dont plan on upsizing mine for the time being in my 1w. and neither has mathers who gets some impressive times
Marshall uses 239mm Discs, that's where the list of VW parts ends :lol:
A lot of people think eliminating roll and fitting lower profile tyres (eliminating the flex in the sidewall) improves handling...and it can...but it can also make the car trickier to juggle near the limit with the boundary between traction and slip becoming very thin.
This is so true. I attended a seminar by Dunlop who couldn't stress enough how bad an idea low pro tyres were on a daily driver. The rigidity of the tyre doesn't allow the rubber to mold itself into the uneven road surface. Pot-holes, cracks etc can easily be taken in a 50 profile tyre, where a 45 would end up skitting straight over them. Not to mention most people on this forum don't have the ability to tell when a tyre is about to loose traction.
There are Civic Hatchbacks running 700bhp at the front wheels, look like right fun to drive :D
If I can find a 13" wheel that'll clear my brakes I'd be tempted to go back and run some 60 profile R13 tyres and get a set of A048's on another set of tyres for track days...
...that or get a good brake set up under the BBS 13" RA's...can then experiment with 239mm's perhaps and different pads etc. I've got VWII calipers in the garage...but warey about using them as like I said all my experience of Polo's on 239's haven't been good. Least I can compare/contrast.
Sidewall is good, improves the ride no end.
Edited by Tav
I don't understand how people can say G40 brakes are more than adequate for standard power?
If I'm having a blast on a local lane (coincidentally a similar if not the same road that Tav will be driving on) I find the brakes start to fade after the first few hard braking moments - and I'm running 8v GTI spec 239mm vented discs, same as the G40. My Golf weighs less than a standard G40 as well, so you can't bring the extra weight into the equation.
Truth is, 62 bhp is enough for vented 239s on VWIIs, if you drive country lanes all the time. So fuck 2-3 times that with them!
there are loads of starlets running over 200bhp with no problems and a hand full with 300bhp all on a 1.3 16v and they are 135bhp standard :-D
Just because they have that power doesn't mean they are any good to drive though...
Don't overlook fluid and pads, they are half the story as far as brakes go.
I plan to use Vented 239's, VW2 calipers, Raicam pads and Motul RBF600 as a track-safe setup.
Yeah but track safe and road safe are two different things, if your car can do 60-0 in a few seconds thats great on a track, but Joe Bloggs behind you in his mondeo probably won't even react quick enough to touch the brakes.
There don't tend to be many Joe Bloggs in their Mondeos anywhere near behind me :lol:
And Danny, you do have a big weight advantage though, your car is probably 680-690kg?
Wanna tell me where you get Raicam pads from?
40bhp. 680kg. no servo.
It all went downhill from there ;)
Italia ;)
Locked up the GT for the first time tonight braking from 70 down through 40...pathetic! Stoopid tyres. Think the little 10mm disks are getting a little warped now. Cannot wait to get the 14's on with the Toyos.
you really are a firm believer that bigger = better.
well it is in the trou.
but not other places.
I never had any problems with the 239 disc on my G40. Drove a lot on a track day after I had gone to Jabba in 2001/2002 and ported the charger. Had around 167 bhp and did left-foot braking all day long. Cheap plain discs, Ferrodo DS2000 and cheapo brake fluid
Mine is a LHD though, with slightly different setup compared to a RHD G40. The bigger servo and the 4 ports used in the master cylinder probably makes it easier to apply the correct amount of pressure to the pads, given that you have a better "feel"
Also take into consideration that from 100 kph a 1991 G40 stops at a shorter distance than a 1991 Porsche 911
