180bhp in a mk3 polo g40
I never had any problems with the 239 disc on my G40. Drove a lot on a track day after I had gone to Jabba in 2001/2002 and ported the charger. Had around 167 bhp and did left-foot braking all day long. Cheap plain discs, Ferrodo DS2000 and cheapo brake fluid
Mine is a LHD though, with slightly different setup compared to a RHD G40. The bigger servo and the 4 ports used in the master cylinder probably makes it easier to apply the correct amount of pressure to the pads, given that you have a better "feel"
Also take into consideration that from 100 kph a 1991 G40 stops at a shorter distance than a 1991 Porsche 911
That says it all really and I know my brakes and car are safe and they are 'suitable' for my car and thats all I care about.
  • Replies 82
  • Views 4.7k
I plan to use Vented 239's, VW2 calipers, Raicam pads and Motul RBF600 as a track-safe setup.
Wanna tell me where you get Raicam pads from?
Well I bought the setup from yoof/henry as VW2, 239 vented and raicam pads complete. If I had to buy new'uns, I'd just get mintex.
my wee squareback was running over 150bhp (but under 170bhp as no aquamist and exhaust on it) and i have to say i found it fine and it has 1.0l springs on the back :shock:( wallowed a few times in some corners but it was getting binned in a few months anyway). but Fk stuff on the front and G40 standard brakes. yeah it wheel spinned in most of the gears and torque steared a bit, but even at speed it felt ok. only in cross winds at top end of the speedo did it feel bit light, but if u drive it right and dont think you are lewis hamilton they are ok i think.
regarding g40 brakes i feel they are "ok for the job, not brilliant but ok and if u look further than the end of your bonnet they will stop u fine like most mk3s.
i tried the expensive stuff and the cheep crap and to be honest for every day use they made feck all of a difference, but i do like my silicone brake fluid, i think it improves things.
150 bhp in a mk3 is fun, you are not super fast but it feels like you are king of the road even if you are not :lol:
I think to many people try compairing them to modern stuff, lets face it if u want the fastest car in the world go buy something else!! and not mater what u do to a mk3 they will still handle a bit poo as they are a 1970s design, yeah u can improve them but eventually u loose the mk3ness. which i feel u have to keep.
Edited by genesisGT
Yep, weight/momentum comes into play.
It is also worth mentioning that I have a grands worth of KW's suspension and fully poly bushed front end too though. Can corner at higher speeds and do not have to use brakes as hard. Did however see 100+ mph 2 times every lap
Running 256 fronts and rear discs with Mk IV Golf calippers at the rear now btw
Edited by G40NUT
i'm sure i've got a medal here somwhere.. i'll post it to you! 8-)
I'm currently running my G40 conversion on Ferrodo 2500 track / road pads, with normal VW fluid, and 10mm solid discs. I haven't experienced brake fade of any kind yet, nor do i feel that the brakes are crap. My car is running estimated 145bhp'ish and the brakes are more than adequate.
My mate has a factory g40, and has done numerous track days in it, with standard everything apart from ferrodo 3000 pads, and has had no problems.
Its not the brakes that are the problem, its the person on the end of the pedal!!!!!!!!!
U get a good set of pads, and get everything copper greased up where it should be, and you'll be fine - Oh, and learn to read the road, Pro-Act instead of Re-act!
Reading the road is all well and good but when driving on a track you aren't using acceleration sense to keep the car traveling in a smooth and progressive manner. It's possible to drive on B roads whilst rarely even going near the brakes if you know what you are doing: half-distance acceleration, read limit points and all the other advanced techniques. On track you are normally trying to brake hard at the optimum point lap after lap...many modern production cars brakes wilt under that sort of abuse...I can't see standard G40 brakes standing up to more than a few flying laps of a circuit. Nothing stopping you lapping quickly on standard brakes...but you'd be far from getting the best time out of the car.
As for running 10mm solid disks with 145bhp :retard: rather you than me.
