Fastest polo Gt ?????
I suppose we are talking about vastly different scales here as well... a 50 shot into a 1272cc engine, or about 400 brake into a 1480cc engine :lol:
  • Replies 91
  • Views 5.7k
By the way, I wasn't being sarcastic. I was with you :lol:
If you follow the instructions, then fitting a WON gas kit isn't hard to get right. I don't have first-hand experience of Holley stuff, but I do know two people that've used it on 1272cc Polo lumps without problems!
Perhaps a bit of trial and error with spark plugs if you're going for larger hits, but hell - it's two jets to select and a bit of research on plugs. You can complicate things with a progressive controller, but I'm satisfied that the 3F is happy to take a straight 50 shot all day long.
Granted, if you get it wrong you can kill an engine - same goes for forced induction though too, and the results can be just as destructive for either... The 3F lump that I treated to a 100 shot of gas without sufficient fuel ended up with slightly knackered rings, still ragged well though - just used oil. The PY lump that got ragged whilst running a bit lean was much more spectacular! :lol:
I think the main reason nitrous has such a bad reputation is because it's too easy and cheap for a random retard to bolt it on to their engine, not set it up or install it correctly, and cause some damage. You could do the same with a 'charger or turbo - but generally you'd need a bit more between your ears and deeper pockets to actually get one installed on a car, so you're much more likely to do it properly - hence the fuck up potential is greatly reduced!
^^^^^ Spot on!
The basic principles remain the same though, again it's not like you're at the cutting edge of technology where no man has ever wondered, it's all well documented and well researched stuff, people have and will continue to write hundreds of books on the topic- the fact that 90% of people chose not the read and learn, and then a further percentage won't put theory into practice, then there are engineers, who take theory into account, and make their own calculated decisions.
And yes a tuned G40 will beat an R32 (how did that come up?)
Can anyone provide me of good sources where i can research N/A tuning? I'd very much like to understand why mods work, as well as which mods work well. And also so i can learn the best way to tune a 3F beyond your average 100bhp bolt-on mods.
One retard question: I know the ports are smaller on a G40 inlet manifold, but why does this mean it makes more torque for a GT engine? Surely smaller ports mean less airflow, and thus less power? I thought torque came from the compression on the pistons or something, like the effect have a lairier cam has.
Excuse my ignorance, its been bugging me for a while!
Two words:
These two books, as well as getting your head round some aspects of physics (air dynamics, such as flow and pressure etc) will see you right as far as I am concerned. In fact, after reading those books I never looked at a vacuum cleaner the same way again, it's mad.
VAW Hillier's Fundamentals of Motor Vehicle Technology (covers a broad range of things, mainly engine and drivetrain)
A. Graham Bells Four Stroke Performance Tuning (goes into big detail and throws some mind bending stuff in)
Smaller inlet ports mean higher port velocity, possibly a trade off for less flow, but better tumble of air within the combustion chamber, faster flame front, more efficient burn, more torque. Put bluntly.
Cheers :D
  • 3 years later...
I know this is an old post, but just reading through it's funny, i've got a polo gt that used to belong to Jeff Seddon, it's got a 1.6 in it, twin 40's, bigger valves, new cam and lots of other work, including a nitrous kit, which i've removed cause it's my first car, but apparently it was getting 250bhp with the nos on, and around 180-190 without. Just saying. :p
Certainly is an old post. Danny Lee has gone and left us since this :crybaby:
How this forums changed!
This bloke knows too much! Been reading his Forced Induction performance tuning. Lots of maths, but understandable principles.
Interested in this. Pics/ Dyno print outs? Specs of engine?
yes defo! pics!
Here's some pictures :) sorry not got any dyno prints or that :S
Direct port nitrous and twin 40s- nice!
Be interesting to see what jetting the nitrous is for- no way your 3F motor is kicking out 180bhp without the giggle gas though mate, possibly 100-110, which isn't to be sniffed at for a first car :-)
Thanks :) and i was just told it was about that hah so not 100%, but its a 1.6 engine that was fully rebuilt like 4000 miles ago hah, have to get it on a dyno at some point to find out exactly what it is :)
I'm struggling with what 1.6 block it is, the thermostat housing and twin oil pressure senders suggest a flat face head, and that limits it to 1391cc when stock afaik - i don't know much about the early 6n 1.6 spi engine though, which i believe has more similarities with the older unit than the mpi units.
Still a long-stroke engine though, so it'll have had some bottom-end work too if it's pulling big peak power.
