Ignition Coil Broken?
Howdy,
I've been experiencing a few issues when under high revs full throttle style driving, and I've narrowed the problem down to the coil
The primary winding resistance is around 3.5ohms where as in the haynes manual it says its meant to be under 2.1ohms
Now is this resistance cause for concern? is a change of coil needed do you think?
  • Views 635
