Mk2 Golf G40 Reshell?
i thought it would be a case of swapping just the mounts, as i seem to remember golf 1.3's and mk2? polos share the same MH code engine.
I've been sat looking at my rough black shell tonight, and I'm considering a u turn and maybe building it up without sorting the minor bodywork issues
  • Replies 36
  • Views 5.1k
Well I've got a GT motor in my Mk2 Golf, so yes, they fit with the correct mounts :lol: as mine was a 1.3 to start with.
What Luke said about the 4 branch needing modded is a bit of a bastard though I hadn't even thought of that.
Obviously if you were to go turbo things would be easier!
decisions decisions
As long as you get a 1.3 rather than a GTI model for a base then it will be more straight forward. This way you will get all the 1.3 engine mounts and drive shafts required. Biggest ball ache iirc is the need to get hold of a custom down pipe knocked up.
from what i remember you want a gti for the
1. arbs
2. fuel tank and pumps
3. wiring
4. clocks/trim etc
you want a 1.3 for
1. engine mounts
2. driveshafts
arb's can be got from a gti, piss easy, fuel tank dont need changin, just pump or get an in-line aftermarket one. Wiring hell no, your best off using ALL the polo engine electronics to make your life easier OR getting a custom loom, clocks can be messed about with till you get em workin or, again use polo ones on custom brackets.
get a mk2 1.3, find someone breaking a GTI (not hard) you'll be fine with 239mm brakes as your car will be light, get a bigger servo and master cylinder if needs be, and PAS is for girls, mk2's feel much nicer without.
HTH
JB
^^^ :lol:
Sorry to lead you on a wild goose chase Pettsy, the mounts actually unbolt and swap over. It would seem I am thinking of Mk1 Golf.
So get a GTI!
you had me rummaging around in the engine bay for fuck all, you really are a gay some times Mr K :lol:
HTH
JB
If you get a 90 spec car the wiring is piss easy...
^^^ :lol:
So get a GTI!
Teehee.
argh, i can't decide what to do now,cheap fix my shell or find a mk2!
how much money do u currently have 2 blow! lol i think will give you the answer
if i had a spare G40 knocking about and some spare cash, this would be something i'd do, but i have neither :lol:
i've spotted a potential 1.3 mk2...going to have a look at it at the weekend methinks!
