  1. Today
  2. 1vw2many
    Had a search but no joy 😊. I'm after a new Mk2f breadvan boot lid gas strut. Please and thank you.
  3. Yesterday
  4. Rupert
    The EA211 1.2 TSI is belt driven, so there's no chain tensioner to blame here. With no fault codes, I'd log the per-cylinder misfire counters in VCDS while it hesitates cold. They can register misfires below the code threshold and point at which cylinder to chase.
  5. Last week
  6. lewb83
    lewb83 joined the community
  7. Aaron0796
    Aaron0796 replied to Connor13a4's topic in Mk2 Polo
    Been a while…but how easy was the splitter to fit?
  8. Yeti
    Total stab in the dark, but I know the old N/A 1.2's had an oil pressure actuated timing chain tensioner. Not sure if these ones do. Might be taking a bit longer to pump itself up when the oil's cold.
  9. Jukka
  10. Rupert
  11. Rupert
  12. Rupert
  13. Rupert
  14. dvderlm
  15. dvderlm
  16. Charlie Cawte
  18. Yeti
  19. Earlier
  20. Mludford
  21. Mludford started following Where to find replacement badges?
  22. Rupert
  23. Rupert
  24. dvderlm
  25. dvderlm
  26. kasialis721
  27. dvderlm
  28. dvderlm
  29. dvderlm
  30. dvderlm
  31. dvderlm
  32. NickJ
  33. Breadvan Princess
