Past hour
Boot gas strut replacement help. mk2f breadvan.
Polo 6C: 1.2 TSI Cold weather, engine runing rough
The EA211 1.2 TSI is belt driven, so there's no chain tensioner to blame here. With no fault codes, I'd log the per-cylinder misfire counters in VCDS while it hesitates cold. They can register misfires below the code threshold and point at which cylinder to chase.
lewb83 joined the community
Mk2 Polo Breadvan Project
Total stab in the dark, but I know the old N/A 1.2's had an oil pressure actuated timing chain tensioner. Not sure if these ones do. Might be taking a bit longer to pump itself up when the oil's cold. -
I'd start with Heritage https://www.heritagepartscentre.com/uk/ Earlier
Nearside rear spring is not broken. I put the car high on an axle stand so the rear axle can pivot and the spring extended fully. Dust cap still on. No broken coils. More tightly wound at the bottom and top. Used a jack to compress it upwards, then released and it descends very slowly. Too slowly to absorb a bump I reckon. Found a piece of hard round 0ne third circle of black plastic inside the spring. Top of a gas shock? -
