  2. Yeti
    Total stab in the dark, but I know the old N/A 1.2's had an oil pressure actuated timing chain tensioner. Not sure if these ones do. Might be taking a bit longer to pump itself up when the oil's cold.
  3. Today
  4. Jukka
  5. Yesterday
  6. Rupert
  7. Rupert
  8. Last week
  9. Rupert
  10. Rupert
  11. dvderlm
  12. dvderlm
  13. Charlie Cawte
  14. dvderlm
  15. Yeti
  16. Mludford
  17. Mludford started following Where to find replacement badges?
  18. Rupert
  19. Rupert
  21. Earlier
  23. kasialis721
  24. dvderlm
  25. dvderlm
  27. dvderlm
  28. dvderlm
  29. NickJ
  30. Breadvan Princess
  31. ajoubertbb
  32. xlimage
  33. xlimage
