1996 VW Polo 1.4SE
I wonder if the base mount of the carb has developed a fine vacuum leak. It should be firm against the rubber, but insulated against vibrations. The rubber hardens over time. Can you wobble the carb left right or back and forth? Will the engine fire with some Easy Start spray (diethyl ether) or a small amount of fuel dribbled down the carb throat? -
