  2. Pistachio
  3. Yesterday
  4. Breadvan Princess
  5. Breadvan Princess
  6. Yeti
  7. DxbPolo
  8. Last week
  9. dvderlm
  10. nige8021
  11. DxbPolo
  12. DxbPolo
  13. dvderlm
  14. dvderlm
  15. BeigeBreadvan
  16. c.w.pritchard
  18. dvderlm
  19. reah.m
  20. reah.m started following Open Air Roof Bars
  21. reah.m
  22. tracey
  23. Earlier
  24. Yeti
  25. dvderlm
  27. dvderlm
  28. Yeti
  29. bigalg13
  30. Alvin.32
  31. Alvin.32
  32. dvderlm
  33. Adam1683
  34. SamHandwich
  35. batesy57
  36. myusername
  37. Paul Summers
  38. dvderlm
  39. Alvin.32
  40. Alvin.32
    Thanks for the response, and no it is intermittent in all sorts of conditions so I believe it isn't due to engine temp as far as I'm aware, usually works until after 8hr work shift. Usually after a drive or two it might manage but afterwards it wont work when I come to try again after a few days. I've had the garage take a look and helped me assumably fully disconnect the rest of the immobilizer as it was faulty in the past anyways, assuming that has now been fully removed from the equation it is just air or fuel starvation. In this case I do have an electric choke I was also curious how it might mix in with this problem. As I already said, it wont start even after days but randomly it will and it seems fine when it gets going, usually drives somewhat well besides idling too long and sometimes when setting off depending on how long I let it warm up, I tend to give it between 2-4 mins. Most recently it started and died after idling for a few mins and hasn't started for two days, I've tried both pumping gas pedal and pull pedal down tricks and doesn't seem to work, my next try would be to check if it smells of fuel or not in carb and check flap. I appreciate the help.
