  1. Today
  2. Yeti
    Total stab in the dark, but I know the old N/A 1.2's had an oil pressure actuated timing chain tensioner. Not sure if these ones do. Might be taking a bit longer to pump itself up when the oil's cold.
  3. Jukka
  4. Yesterday
  5. Rupert
  6. Rupert
  7. Last week
  8. Rupert
  9. Rupert
  10. dvderlm
  11. dvderlm
  12. Charlie Cawte
  13. dvderlm
  14. Yeti
  15. Mludford
  16. Mludford started following Where to find replacement badges?
  17. Rupert
  18. Rupert
  19. dvderlm
  20. Earlier
  22. kasialis721
  23. dvderlm
  24. dvderlm
  25. dvderlm
  27. dvderlm
  28. NickJ
  29. Breadvan Princess
  30. ajoubertbb
  31. xlimage
  32. xlimage
