Might try that as the 7062 bolt has not arrived yet and the trains are sadly abysmal. Waste engine oil must need good pre-filtration. Rudolf Diesel used peanut oil in 1900 Paris exhibition. Lots of sunflowers and rapeseed grown near me. Earlier
1996 VW Polo 1.4SE
I wonder if the base mount of the carb has developed a fine vacuum leak. It should be firm against the rubber, but insulated against vibrations. The rubber hardens over time. Can you wobble the carb left right or back and forth? Will the engine fire with some Easy Start spray (diethyl ether) or a small amount of fuel dribbled down the carb throat? -
