  2. lewb83
    lewb83 joined the community
  3. Yesterday
  4. Aaron0796
    Aaron0796 replied to Connor13a4's topic in Mk2 Polo
    Been a while…but how easy was the splitter to fit?
  5. Yeti
    Total stab in the dark, but I know the old N/A 1.2's had an oil pressure actuated timing chain tensioner. Not sure if these ones do. Might be taking a bit longer to pump itself up when the oil's cold.
  6. Jukka
  7. Last week
  8. Rupert
  9. Rupert
  10. Rupert
  11. Rupert
  12. dvderlm
  13. dvderlm
  14. Charlie Cawte
  15. dvderlm
  16. Yeti
  17. Mludford
  18. Mludford started following Where to find replacement badges?
  19. Rupert
  20. Rupert
  22. Earlier
  23. dvderlm
  24. kasialis721
  25. dvderlm
  27. dvderlm
  28. dvderlm
  29. dvderlm
  30. NickJ
  31. Breadvan Princess
  32. ajoubertbb
  33. xlimage
