Past hour
Third week of driving it again daily. On the plus side: The starter circuit is working really well. Pull the new choke cable all the way. Don't touch the gas pedal at all. Turn key. Instant start. After about 10 to 20 seconds it can pull away. Before that it dies. Drive off, push choke to half way after a 100 yards or fully in once the throttle feels responsive. I did use the engine preheater this week. This morning that was great as it was -2°C overnight. And I'm on the skinny 4.5" wheels and winter tyres already, with the huge radiator one third covered. No warm air feed required yet. Filled up as fuel gauge needle was just entering the coloured reserve band. I seem to have managed an astonishing 419.7 miles on 36.35 liters of Momentum 99, which I reckon is 52.5mpg or 5.4 l/100km. (I have a 42 liter tank with supposedly 6 to 7 liters reserve left at that reserve point) I reckon people are driving more slowly, 20mph limit in town, 55ish on A-roads, and I've been trying to do any commuting to/from work at quieter times of day. On the negative side: Exhaust bracket is drooping from the chassis at one end so exhaust is dangling but the 2 rubber bands are still attached. I blame the potholes and speed bumps. I reckon the pump jet stroke needs a slight tweak to increase the shot volume, exiting a roundabout and accelerating out needs a bit more oomph. New cars' headlights are so dazzling bright. Petrol is how much? Still not used the radio. Last week
