Alpine White GT Genesis
god that looks good ! i need a set ! :lol:
  • Replies 186
  • Views 20.2k
  • Little bit of catching up, this time for the GT. Plans changed for it, don't use it that much so decided it doesn't need to be comfortable, and this will most likely be its last year on the road. I
  • Uploaded 1 GoPro video so far, this time taking Steven out on the Eastern circuit.
  • Been a while since an update, went in for MOT a couple months ago, failed on brake flexis and a missing exhaust rubber. Ordered some bits while I was away working, surprisingly it started no bo
A few photos from earlier, managed to snap the handbrake cable at the drum too sad.png
Love the look of this!! Makes me want one even more
Getting used to taking the rear brakes apart, third time now this morning!
Replaced the broken handbrake cable, pretty much had to take both sides apart and start over again.
While it was all apart, thought I'd try do something about the toe in that the camber shims had made. So whipped them out in place of a 3mm washer at front and a 2mm washer in the back, probably not ideal but has helped, bit too much camber now though!
D3CA7C5D-98BE-416F-A5AC-42DA3D09732C-183
Hmm...
A3544706-B3D3-4F06-87CC-2ABD81E6A36A-183
D752B17A-5AFD-4832-AEFB-E5CA617A15F2-183
Bit of an update.
Currently the idle is a bit weird and the throttle response is sometimes non existent, so had a dig about to see what looked worn out, fitted new dizzy cap, couldn't get the rotor arm off, got a new rocker cover gasket to hopefully stop the slight leak, and noticed the fuel filter was ancient, after a lot of faffing about that's swapped out... Time to play sensor bingo I think!
Also gave up on the polo centre caps, they don't line up quite right, so sprayed and fitted the audi ones for now.
Photobucket overload!...
Found a good place to sit.
fd08bb7a1ff53fe68dc77ab8b6cea8c8_zpse066
Got some tape to tidy up the wires at some point.
f18189867f04948148d5180d389ad16a_zps5abb
C91632F8-5576-4A5A-A851-272B454DFC22-127
Bolt hold holding on the filter was well on there.
70EAE0F9-529C-4B18-9359-4F40F018A92B-127
Seems ok...?
154953d45d648aa107d742327ee3b7b0_zps1366
Sorry brake servo.
61ceb3f036648c22fd6936257712bebf_zpsf0a5
0B518F98-0B8E-443A-ADE5-D2D2E4058010-127
AE0DC1E3-B7F2-4AB8-9D94-F150047C833C-127
50B3A375-8ADE-4FEF-A461-188A6C7FFADF-127
Skies were clear so went for a play with a fisheye.
The wheels don't show up too well in photos, but I like them enough in the metal to keep them black :)
How the ride quality on the 15's? Was looking to get some 15's but hear to much bad things about them so in 2 minds
They do look great imo
I don't find it any different than 13's. smaller sidewall but slightly larger diameter rolls over bumps easier.
Suspension definitely has more of an effect!
That's cool, got some BBS rm's now so gonna get some lips n hopefully they'll be ok. You get any scrubbing at that height?
Edited by K Dotty
Only at the rear,front bottoms out before hitting arch.
It's the plastic arch bit in front of the rear bumper that needs trimming at the top, if that made sense...
Recently got a suction mount for my GoPro, thought I'd give it a go while driving a few places in town.
If you've got 15 minutes to kill, switched up the view a few times, came out pretty good I think.
Need to go for a drive on some back roads at the weekend!
Go pros are ace eh?
Some good angles you got it at. Thought in the first 5 minutes you were going to go for a proper whore tour down the harbour haha.
Never knew I would like silver wheels, but its nice to actually see them!
Looks great on the silvers!!
I've always preferred lighter colour wheels can actually see the pattern of the wheel then. Silver goes nicely with the white
Aaaaaaaaaand it's gone...
561D0AC9-CE89-4FE9-B0FB-E5CBC2DE1326-483
6513C798-D65C-4D08-B888-EFDA875486F8-483
783751A2-C780-4916-8CED-AF2658FECE76-483
25CC9777-9803-4E44-9E69-6BAB00D77F74-483
It's replacement.
D4C4094C-B3C2-4F88-BCA5-119E9C220062-483
Bits, bits, and more bits.
EACECE66-0251-4955-A8BC-8488759ECE9A-483
85A16731-DF5E-495F-81CC-71345767661B-483
Well that was a polo filled weekend!
A massive thank you to steven (kwijibo_coupe) for putting up with me and getting the GT swap done, still some running issues to sort and source the rattle, but its in!
Here's some photos from yesterday
CFCF6AA6-51DE-48F5-AB73-2131C4C3563C-788
25813EA5-97AE-4B67-8C62-B25F701B1421-788
A17A2B6C-4F12-4B4C-9BFA-88E6F1B0FE01-788
26067C92-6344-43B5-AA2A-CE617C5EA2C3-788
E4CAE51D-C2CF-4731-B8CD-7A40C222B910-788
And the G40 getting some attention :)
8A56FF80-79F7-47F4-B29A-21415308D811-788
Well, that was a fun drive home. Can't believe the difference!
Got a 6n engine cover too and adapted it a bit.
17F41802-087B-492C-BB1F-D49AFD3AF52C-174
Also, coming soon...
A61ACC6C-9B84-4B36-B883-2EB16F3C32CC-174
...another update, just finished wrestling the ARB blocks on.
B19218B7-B53A-4F3D-9368-81CEA6EF8671-265
30FF911C-8B3B-438B-B807-E36D438DB53E-265
This happened sooner than expected, due to a cancellation at Turriff Tyres, went for a trip up this afternoon.
So the 4-2-1 manifold went on, the cat is gone, no centre box, to a similar to standard size back box, with an original as possible looking tail pipe, all done in 1.75".
New mounting point for the back box is much more sturdy.
Sounds pretty sensible on normal driving, but over 4000rpm it sounds nuts!
And now I actually have some ground clearance :)
A3A20928-9D28-4A77-AAB0-878B27E95B24-326
D4DE333A-6AED-4C19-A835-52519968B15F-326
5BC09873-2A52-4533-8AEB-C34E5719CEB3-326
8AFF375E-8EA5-4D99-9350-B5E674B74DE6-326
A35188F4-C67C-4BB7-B89B-04B31C260724-326
15AB75C2-CD34-4BF2-B8D1-8C7E3B544CA2-326
35ED11D8-6C86-418E-B591-7296F7824D44-326
Tidywork on the exhaust!
Had a play with the gopro again tonight, have about an hour of footage to go through of me and steven in his G40 driving about north of Aberdeen.
While I'm working on that, made a short video of the sound of the new exhaust, had the radio off and window down since it was fitted haha
http://youtu.be/4WFMQ_rMzxA
Edited by citrus
Tonight was a good laugh, haven't driven those roads like that in a good while.
Had a quick look through my videos, should be able to piece a decent driving video together.
Your exhaust does sound well nice, money well spent if you ask me.
Don't know about yours, but above maybe 30mph all I can hear is wind noise, it's really annoying.
Though got some good videos of you dissappearing into the distance!
...also, found a weigh bridge on a farm, so me, the polo, a box of tools and 6 gallons of petrol came in at 860kg.
That makes the polo on its own about 750kg, sound about right?
