Black Coupé GT converted & tuned
Me too haha, never put it on though!
  • 5 months later...
  • Replies 65
  • Views 16.8k
  • a few pictures of some prep before it was sprayed, these are from around 2011 it earned its keep for a while, loved driving it for work. people liked seeing an ol
  • been alot going on since the last update This greeted me the other day thanks also some more bits arrived in the post fog lights and loom I wont fit them right away, will measure the loom and g
  • some more bits painted G40 inlet built up with blue top 249cc injectors. engine / alt mount & drive shaft guard
A friends mrs reversed into the side of my polo the other week
Its not as bad as it could be comsidering its position but it is worse than the pictures show, basically pinched the lip of the arch.
Some more dent removal
Also had this to sort out
some pics of the repair
the paint still needs rubbing back and waxing to blend it it
Edited by kiran_182
new rear brakes
still other bits to do
  • 6 months later...
Been a while since i updated. Not a great deal going on with this really as its full spec now, well almost
Took it to the scirocco nationals yesterday at raf cosford. 200 miles each way, did it without a problem and more than capable of keepin the pace with all the roccos
Had to park in the 'peasant parking' area as i didnt come in a scirocco
Locked it and walked away, didnt give a thought to opening the bonnet as i didnt think itd get noticed umongst all the sciroccos but quite a few people looked it over, probably to work out what it was "thats not a golf, what is it?"
Got a quick look at jons new g40 too at one of the stops. Thats and audi coupe gt next to it
Edited by kiran_182
After nearly 10 years i sorted the sunroof, not the way i wanted it to go but it needed doing. Silicone finger prints everywhere
Needs tidying up but itll do for now
  • 4 months later...
Not a great deal gone on with this, added a golf afm and cone filter which had increased performance higher in the revs but lessened it lower down
Edited by kiran_182
The golf afm does make a difference to the mid and higher rev range, losses a little low down but its worth the swap
I did try a smalled cone filter as the large over breaths low down and again it was the same effect , quicker 20-50 but becomes restrictive over that
Idealy id like to modify a gt airbox to fit the golf afm
Detuned the polo, gt injectors and airbox back in
Gonna go at it again with less guess work to find some extra horses
Quick pic if my cracked 421
That's a bit shit. Just fatigue or is there play in your engine mounts?
Been on there 7 years so cant complain. One of the backbox hangers has had it and the rocking probably did it, could hear a blow under me but couldnt quite see it.
Did notice a mark where the crack is but it looked more like a scratch at the time
Would have been nice to find out what it makes
This is the 421 as it came out, didnt even try to keep it in ine piece as it would never have happened
Had it repaired, welded and the plated on top of that. Got it back in, bit of a job
  • 10 months later...
Guess its time to update the spec
Engine
• 1.4 abd
• newman 270 cam
• GT multipoint injection
• G40 gearbox & high torque clutch
• G40 inlet & 249cc injectors
• mk2 golf gti afm & cone filter
• 8k chipped ecu
• 421 manifold jettex g40 exhaust
• twin core ally race rad
• 8mm ht lead
Brakes & suspension
• vw2 front breaks vented discs
• mk2 golf gti rear disc conversion
• ta 60/40 kit
• ppp stage 2 subframe powder coated metalic grey
• poly arb blocks
• poly bushed GT rear beam powder coated black
Interior
• scirocco GT seats & genesis rear bench
• GT clocks
• GT steering wheel
• GT branded gear knob
Exterior
• respray in original colour lo41
• clear indocators & side repeators
• smoked rear lights
  • 8 months later...
The polo has come to its end, parted out and the shell givien away to improve a black gt
