Adjustable fuel pressure regulator
(middle one) Sytec pro-flow regulator adjustable from 1-5 psi, chrome finish with 6mm tales. Very little use, £13 posted or collected from horton in slough, or addlestone.SOLD
(Left) Adjustable regulator suitable for reducing pressure from a high pressure injection pump to low pressure for carbs. It has a return to tank and turbo feed but is just left open on na engines. 8mm tailes, very little use as i was given a low pressure pump so no need for this regulator, £30.
Unused adjustable universal regulator for injection with pressure gauge, works from a vacuum on the inlet. £12 SOLD
Edited by neb
  • Views 887
would any of these work on my AEE engine ?? to boost the fuel pressuree !
i was thinking that but for a G40!
the one on the right will i think as long as it fits the fuel rail, i know you can buy adaptors though
I'll take the one with the guage. Will you take £15 posted?
Edited by deajam
bumpage
