Polo Coupe S
Bit of a feeler really as I haven't had it long. This is the second time of owning this car and I enjoy it a lot but feel I need to start saving money and stop modifying cars! Looking for a swap or p/x for something standard and reliable. ANYTHING CONSIDERED
Description nabbed from previous owner (thanks Goose :p)
Year/Reg: 1987 D35 KYB
Mileage: 120k odd(will double check) Will go up slightly as I'm still using it
MOT: 12 months 8th Dec 2011
Tax: June 2011
Good Bits -
Exterior/Chassis:
Lowered 80/60mm on PhilJ coil/damper kit. Just had new top mounts put on, tracking was done aswell.
Genuine BBS Mahles 13x6 wrapped in 165/55's. The tyres were new less than 2000 miles ago, wheels had a quick refurb before the tyres were put on. New bolts aswell.
Rear wheels spaced out 10mm each side using high quality blocks between the stub axle and rear beam. Alot better than the normal spacers, easier to change wheels and does not wear out wheel bearings.
Rear wheel bearings replaced less than 3000 miles ago.
Rear drum cylinders replaced less than 3000 miles ago. All brake fluid was also replaced with new Dot4
Rear wiper has been removed, it will all come with it though.
Aero wipers
Everything else exterior wise is standard.
Engine/Exhaust:
GT head/cam and block. Block was hammerited black before it was put in.
GK inlet manifold. Again not the easiest things to get.
Webber DMTL carb, manual choke. Has a genuine VW choke cable to fits in with the dash perfectly.
Still running all the original mk2 ignition system.
Facet electric fuel pump that has been hidden away in the skuttle tray.
8P gearbox, clutch was still good when engine was changed over.
Exhaust has had the middle box removed and just has a back box for clearance. Barely ever touches the ground, sounds alright aswell.
The cambelt and water pump on the GT were changed shortly before I got it, I've had it barely anytime. Not totally sure on the mileage of it but it runs very sweet, doesn't use any oil. Oil and filter were also replaced less than 1500 miles ago.
Haven't had it rolling roaded but feels like a good powerful engine with the webber and GK inlet. Loves to rev and will happily go right to the end of the rev counter. My original plan was to add a 4 branch manifold and GT gearbox which would would finish it off perfectly and be pretty quick.
I also have a windscreen washer fluid bottle that goes in the boot so the one in the front can be removed to give a cleaner bay. I haven't had a chance to fit it yet but will come with the car.
Interior:
Recaro front seats, not sure what they were originally from. The original seat runner have been welded on but sit a lot lot lower than standard. Gives IMO a nice driving position. Unfortunately the cloth on the seats isn't great condition, but the foam is near perfect which is the more important bit so ideal for a quick and easy retrim.
Mountney leather steering wheel and boss. Very small, great fun round twisty roads.
Leather gearknob
Has some Sony Xplod component speakers in the rear parcel, previous owner did this. All original speakers are still in the car though.
Not so good bits -
The worst bit is basically parts of the bodywork, being the passengers front wing, which ideally needs replacing as it has a rust hole in the bottom corner. The bonnet has obviously had the passenger corner resprayed but not blended in very well. Areas of primer as beginning to show in the roof, obviously from being previously over T-cutted! There is also a scratch in the roof that has gone down to primer.
A couple of dents and a couple of minor surface rust spots, which are to be expected of a car this old.
The fuel gauge and temp gauge don't seem to work properly. The temperature gauge is intermittent, the engine never over heats so isn't too much of a concern. And the fuel gauge will only read just above half way when the tank is full. I haven't really bothered looking into this problem and just got used to it.
The alternator appears to be making a noise as if the bearings are slowly on their way out. Still charges the battery up fine though.
Overall its a great car that gets lots of looks and compliments. Lots of fun to drive, and mechanically pretty good. The only thing that really lets it down are the areas of the bodywork mentioned, which could easily be fixed with a trip to the scrappies.
All the spares I've got, will also be thrown in.
More pics here: POLO PICS
Price: £800 but as said above would prefer a swap or p/x or £650 on steels!
Edited by jackpeters125
  • Replies 37
  • Views 3.8k
any pics of how i stands now cause you said it was derby set up and the pics dont have that
That's an error in the ad as he copied my old one. It doesn't have derby bits as I kept them.
oops, yer sorry about that, edited ad now. Comes as it is in pics.
Swap for a 97 polo saloon? e.windows, e.mirrors, central locking etc etc
Got any pics?
would you swap with a mk 1 caddy bands coils tax and test ??? (:
swap for renault meganne 1.4 8v 2000 model dark blue central locking electric windows cd player 120000 miles on clock good runner recently had new head gasket +valves+valvestem oil seals +timing belt and tensioner badly want a coupe s someone crashed into bk of mine gutted cheers
Not really what I'm looking for but got any pics?
Passed MOT today and will have new radiator from tomorrow as is leaking slightly.
Bump £800
mk2 scirocco 1.6 gt?
Got any pics? Can you send them to: jackpeters125@gmail.com
Few pics of problem areas etc
CLICKY
pm'd u mate
Bump, found a car I'd like to get! Will have 6 months tax and 12 months MOT from tomorrow £800!!
Hiya dude, sorry for massive delay in replying. Thanks for the pictures, really helpful. Really wanted to come get it but having returned to UK I've discovered a few large bills i had to pay which have eaten a large part of my car fund, looks like il have to wait til i return in spring. Really sorry to mess you around but good luck with the sale, someone really needs to come take this off your hands!
Hey, no problem man. Just figured you didnt want it, thanks for free bump anyway!
Do u wanna swap for a renault meganne 2000 model 1.4 8 v cheers
Youve asked me this before, got any pictures? whats the condition like, tax and MOT etc?
Hi jack,
Really interested in the polo mate is £800 the least you can take for the polo cash?
I am going to minehead butlins on the 30th of this month and may be able to pick it up then if the price is right?
let me know
Hi jack,
let me know
PM'd you mate
is this sold?
Hi jack,
let me know
PM'd you mate
Nope not sold yet, Been really busy last couple of weeks so haven't been able to get any more pics.
Hey! As lovely as it is I'm after something a bit more standard. Id be too tempted to spend too much money on your golf :p
