Polo 9n to 9n3 rear lights wiring
Following on from this thread
http://www.tigerstyle.co.uk/phpBB3/viewtop...=439041#p439041
I can't get hold of the guy that made the adaptors, so going to try make one myself.
I need the part numbers of the things i require, anyone know what they are?
  • Views 5.4k
If you want to make things a whole lot easier for yourself check this thread out...
Tutorial: 9n to 9n3 rear light conversion, spice up your rear end!
It's just a little changing of wires, you can even use block connectors :D
thanks, i tried getting the wires out the pins but it werent working, i thought making the adaptors should be much easier
You could just cut the wires and strip them?
