Mk1 golf rear coilovers
Has anyone done this before ??
Edited by john-125
  • Replies 32
  • Views 7.5k
yes its been done they do fit with a spacer at the bottom where it bolts to the rear beam
Ok m8 thanks :D
and at the top as there to short
Fitted the coilovers yesterday all fitted fine but had to use spacers on the bottom bolts all else was fine :D
you will find its pretty much decked, you really should add a 20/25mm spacer to fit at the top so you can use some of the threads of the coilovers and lower it much better then having it wound all the way up
had that problem on my one with the 6n coilies yeahh lol
plus without a spacer they stick out too much fr you to get the cap back on the top so they look gheyyyy
I had to run top spacers too, there was very little adjustment without them to the point of where you try and raise them to sit nicely with the front and all it was doing was taking out the preload out of the helpers
aup mate jw what spacers will i need and what kind of spacers cheers
Read the thread and you shall see ..
This,
Also how do you run without the top spacers? Theres not enough thread on my KW's to do that?!
Think cheaper coilovers have more tollorance etc .. My mates coilovers have got like 3-4 inch of thread lmao
Yeah mine were fine. Had just enough thread
I seeee, well mine came off a 6n2/6n1 and came with a rather long spacer anyway.... was 2" bar iirc. was perfect :-)
might have to order mk1 golf coilovers and will they fit on without spacers btw iv got a mk2 breadvan
Can't you read? You quoted a post saying it needs a spacer ffs!
Most people on here want us to actually go fit them for them ?
Start telling the the asnwers the want to hear even if they're wrong lmao
theres many a thread about using mk1 golf coilies on the rear of a mk2 or mk2f but there arent many pics to help i have found so I'm still not sure but i thought i'd add it to this one
I've just bought these:
mk1 ta technix with what looks like the spacer on the top people talk about?
but the bottom seems like it doesnt have a spacer/washer or is this it?
I'm a coilover noob! :roll:
you add a spacer on the bottom, 3 or 4 washers iirc if you want a quick fix rather than cutting bar... yes that is the spacer on the top some people dont have, like you i had that spacer already too.
where? actually in the hole as the diameter is too big or is it because the existing part isnt long enough where it attaches if you get me?
Because the bottom "eyelet" isn't wide enough, so when fitted to polo rear beam, it would just move about. You need to "pack" the bottom out with washers to get it to fit snug into the area available.
:nod:
I Fitted a pair of these to the back of mine last week. almost a straight swap except the spacers & a lot of winding of the coilover nut.
Ben is yours different because its from a 6n/expensive?
i tried fitting the whole 42mm spacer /top mount sleeve from the raceland mk1 coiliys i have, and it just wouldn't give me enough thread, so it was cut in half and i now have 2 20mm spacers one on each side, does the job great.
No idea mate, they're off a mk5 originally, same thing though. i did have to jack the beam up to get the nuts on inside the car but its all good. no bodge as such :-)
