Ibiza cupra in 6n seat frame help
OK so got my seat Ibiza half leathers today fitted them no probs straight in apart from removing the seat clamps on the rear
They look really good I'm happy with them
But the driver seat frame is mashed
The leaver to the left won't hold the seat in position it you lift it up it just falls down ie highering and lowering the seat position does not work you can raid it but if you sit on it it just falls to the lowest position
Also when I sit in the seat it leans back and twists to the left side , its not stable at all
No The base upon inspection looks the same as the 6n fronts
Can I change theses , and how do I do it and is it hard
Or can I just change parts
On close inspection the teeth that hold the seat in height position the cog is mashed on the teeth and there is some kind if weld
Please advise
  • Views 887
I had exactly the same problem when I fited the leathers to my Ibiza.
Remove the backrest, remove the base cover & cushion, from the leathers, strip your old seat to the same, then fit the leather cover & cushion to the old base frame, refit the backrest.
Here's a guide on how to do it 6N Seat covers.doc
Awsone so it can be done brill thanks nice project for tomorrow
