headlining swap
I have a car with early-spec light interior, but i will be acquiring a full dark interior soon. However, the nasty creamy/beige headlining thats in there will stick out like a sore thumb. My car does have a dealer-fit glass sunroof, so metal sunroof model headlinings won't fit. I may be able to acquire a non-sunroof headlining though, but i am told that swapping them is a real ballache even for a pro. Is this true, and has anyone attemped it?
If i don't swap it, will something like VHT Vinyl Dye do the job of spraying it all black? And does anyone have any other solutions?
Thanks!
  • Replies 9
  • Views 1.8k
Never done one, but seen one done on a Scirocco at the Phirm one Saturday.
Took my mate Paul over 6 hours, to do it properly you need to take all the windows out.
You'd need a non sunroof one if you have an aftermarket sunroof.
Would it be expensive for a pro to do it?
No idea, I'm guessing they'd want a good sum, just because it's such a ballache to do.
Damn. Is spraying it black a bad idea?
its dooable, the biggest problem i can see is where it meets the windscreen, but you could get around this
you WILL need the back windows out, and to pull all the trim off where it meets the headlining and the front door seals, not sure avout whrere it meets the boot
i've been quoted £200 for a new one fitted by a pro in black alcantara just for comparison. not VAG one, just one made and fitted like i was having a retrim.
I sprayed my headlining black and it was a piece of piss mate . Just mask everything off properly and your good to go .
It will work, but to do a tidy job just give yourself plenty of time.
VHT rules!!!!
As regards removing a headlining, I have done a few in Mk2 Golfs and had to repair/remove sections of the headlining to repair the Bee-sting aerial in Sally's G for her.
Again, if you do give it ago, give yourself plenty of time.
Use a hair dryer to remove the sticky glue from around the back windows etc and peal it all back slowly.
Re-fitting can be an arse.
The major roof panel isn't too bad, as it is on metal rails. To finish the job well, getting the A,B,C pillars right can be tricky
bringing up an old thread, but my coupe has a black headlining, and its sags like a bitch, i know it has metal rails but i just cant seem to get them back in. Any tips anyone:?
