Prepping a bonnet for paint
basically i want to paint my bonnet matt black atm its green with a fair few stone chips which have been badly covered with a chipstick.
an i've never painted bodywork before so i jus wanna check i do things right. I'm assuming that first of all i'll have to rub the whole bonnet down so the paint will stick and i've gotta rub the chipsticking down.
is there anything else i have to do and are there any pointers for a first time painter?
Newman
  • Views 1.2k
I would say you should coat it in a spray primer first so its all smooth before you put paint on but you dont have to..
You should take the bonnet inside when painting as i had to pick several little fly's off my bonnet lol does get annoying.
Wind can also take most the paint away before it hits the bonnet. itl take about 2 cans of paint to get an even coat(from my experiance) across.
rub it with 800 wet n dry paper...use warm soapy water
its up you how far you go...take the shine off , or keep sanding and feather out all the chips
if you sand out the chips the bare metal will need some etch primer on it, give that a little sand and go ahead with the top coat
flat with 400 and do nice even coats :)
cool cheers guys i'll get on that job 2moro night!
400grit wet and dry, 800 is to fine.
no need for primer if you just rub down the paint leaving no bare metal.
KiZ
