removing and smoothing roof drain trim!!
I been thinking of lots of body modds to do and i have a few on my list but just throught of anouther!!! has any one removed the two bits of metal that stick out of each side of the car and run along the roof, i think there to let the water drain off the roof and down the front/rear of the car.
been done, any pics or advise please!?!?!
cheers all!
  • Views 1.3k
it'll crack theres too much flax
There was that silver one that had the gutters removed.
Yea you can do it, but only if you're a good welder or know a good welder. Gotta chop them off and weld up the gap, but it has to retain the strength and shape.
yeah it used to be common mod years ago on custom cars....you'd need some proper skills to do it....i believe you grind a few inches then weld it and so on
^^^^^correct but unless you know what your doing and you get a decent body shop to do it you will end up with a wavy roof as sheet metal doesn't agree with heat
wow didnt think be that crazy!! might have steer clear then!! one guys i work with does welding but dunno if be good anouth to do this!!!
