rolling road results!
119.8bhp! very gay, probably down to me crappy filter, i most certainly will be lookin at a new one soon, since I'm payin an insurance premium for it losin power grrrr. will hopefully get a scan of the printout put up later
  • Replies 15
  • Views 1.4k
Not surprised, dont ever expect the manufacturers figures from a car, take into account, engine wear & tear, rolling road configuration, temperature, tyre pressure.
For a 7-8 year old car, only being down on ~5hp is no big deal!....infact thats quite impressive and says a lot about VWs engines!
I dont think adding a different filter really makes that much difference to be honest with you....the standard airbox seems to work quite well....
The weakest area of the engine is the intake between the throttle body and the engine...
If you converted the engine to run on sepperate throttle bodies with a custom, tuned, intake manifold you would get some quite considerable gains....
Vw did a fairly good job of getting a lot of reliable power out of the 1.6 engine in the first place.....its kinda a shame about the gearbox because, the engine is pretty much ready to have a supercharger slapped onto it with a few minor changes....
Still should have at least stock. Mine got 126.9bhp with just a BMC. Had another GTI on the same day and the same rolling road achieve only 122bhp, and that was with a de-cat exhaust
Obviously everyone here realises you can not and never will be able to accurately check power outputs using a wheel dyno...
IMHO...you can cry and whine about loosing a hp or two...spend a fortune on go faster bits and still not get much back...
Or you can throw out the spare tyre, the aircon, the big speakers, the rear seats, cd changer, carpets etc....and perhaps loose 30-40kg.....that equates to a hp gain of roughly 6....and with less sound deadening you should feel faster because of all the noise
Mine is stripped out...I don't have my parcel shelf in nor the rear plastic trim on the inside of the tailgate. It's rapid now :D
ha completly agree, its all about having a striped out car, no need for maahhoooooosive speakers!!!
did you run it in boldon?
rollers are shit loads of people have had wrong readings if its there.
Edited by supercharged spaniel
i managed 103bhp from my standard valver
is there an accurate way of measuring power then?
engine out and on an engine dyno tbh
yeh i got it done there at vsport cos me cousins mate owns the place lol
as far as the filter goes its not the standard one, its a piss poor induction kit. i know its a crap one anyway, because the filters not getting cold air in or anything, cos theres no direct feed for it, its always hot from the manifold below. could be lookin at a k&n one soon like
got the printout scanned in here it is for all to see
couple of unexplainable dips on the power around 4k n 6k which are bit weird but otherwise nothing special
I took the sound deadning off from the underside of my bonnet yesterday, looks so much better!
Gonna take it out of the boot as you have done aswell!
Time to compare!
