What type of plastic to use for this....
I wanna know;
What is the best plastic to use for the section between the front and rear side windows..... Any ideas?
(And where d'you get it from!)
Edited by Fonz
  • Replies 14
  • Views 2.3k
why don't you just paint them?
DKnight on here does decals heres a link:-
http://www.volkswagenstickers.co.uk/index2...arch&cat=10
They're a bit pricey.. :?
Anybody done it with textured sticky back plastic?
Seen some stuff online called 'fablon' - does anybody know anything about it?
Come on... £16 and they're all cut to size, the right stuff etc.
I mean I'm tight... but jeeeeez.
rolls of fablon from wilkinson are like £3 stick it on, smooth it out and trim the edges :)
easy
It's still £16+p&p for four plastic strips! Is that what they call scene tax? :-D
How durable do you reckon this fablon stuff is?
Scene tax? come on....i mean, if they were 50.00 i could understand....but 16.00 plus what, 2 quid p and p is hardly scene tax. U try buying a sheet of the material dan uses to make these, and see how much it costs you..........bet its not far off from the 16.00 he charges...and he cuts them, and packages them for you for that......
i have a set, and haven't fitted them yet,.........however, the material used, is a direct copy of the original...i held mine up against my mates g40, and u cant tell the difference. even the mottled pattern is the same. if u want you are b pillars to look good - this is the way forward!!!
Well, I'm pretty poor! :-(
Nothing against DKnight - you have to sell stuff for what people will pay - I'm sure his products are excellent! Maybe I'll try a set after all.... :thumbsup:
Maybe I could try Fablon, and if it looks shit, I could put the 'proper' stickers over the top! :-D
I'm so tight i used a sunstrip that was free with a 1997 edition of fastcar magazine on one of my old polos! it stayed on fine so i would imagine fablon would work just as well!
Textured paint can also work. Mask up well though.
my drivers door is missing one, only noticed yesterday and I've had it for 6 months.
i'll be after a set soon. Drivers side on mine is cracking!
I used the £3 a roll stuff from Hobbycraft,which had enough to cover the entire car,in the rear licence plate recess on my MK2 coupe. But its shrunk slightly in the sun - not much,but just enough to make it come away from the panel in the corners. Its being re-sprayed soon,and i'll probably use the dearer stuff.
fablons great stuff used to have a wood effect of it down the sides and lasted a year before showing any signs of age so use t
