Rockford fosgate surround sound processer
brought this a while ago now intending to use it in my car to play out films and music in dolby pro-logic. Seems it doesn't really mate up with the EPX2 i already have so its never been used, is brand new and still in original box. Will be posted 1st class recorded so its arrives in one piece quickly!
Edited by vwmk3jon
  • Replies 11
  • Views 698
UP ^^^^^
ttt
how much you looking??
its worth quite abit but its as much use to me as a chocolate fireguard! Postage is roughly £6 so £26 posted?
Got pic at all and would it be compatible wid rockford punch amps etc what model is it by the way aswell
Edited by polo boi1
Sorry, not a great pic. webcams are pretty lame! This unit will work with any brand of amp. I was planning on using it with my power series amps until i realised it wouldn't work with my EPX2. You have a front and rear RCA input (from headunit). The signal output is then split into front, rear, subwoofer and centre speaker. So basically, you'd have 2 sets of RCA cables going in and 3 1/2 going out as the centre channel only needs one cable. There is also a switch to turn the centre channel on and off.
Along with the main unit, you get a standard length cable which plugs the remote display (also included) into the main unit so you can have the display on the dash. This has 5 lights which show you which speakers are live.
Finally, you get a set-up disk which really helps you to set the unit up.
I know that may sound confusing but its real simple when you actually look at the unit.
If you want to look it up, the reference is RFQ5000.
found this which may give you some help???
http://www.rockfordfosgate.com/forum/topic...p;TOPIC_ID=3334
up ^^^
up
up
up
NOW £15
