Converting 5-door seats for a 3-door
Is it possible to convert seats from a 5 door to work with 3 door.
As the front seats on a 5 door do not have the lever to move the seats back and forwards, but i've been told that the mechanism is still there under the cloth, all you need to do is cut the cloth and stick the lever on it.
Has anyone done this or knows if its that easy?? cheers
  • Views 642
i have no idea.
but... you should should probably post this in the technical section.
just lower you car loads so that you cant take any passengers in the back anyway :D
