new gasket?
any body know how much a new head gasket, and re-skim is gona cost me on a 1.4 8v 6n? orr does any body know anywere in derbyshire or near derby who could do a good job or a cheap job :) orrr if anybody knows any garages which could do it for me, i would have the GT camshaft fitted aswell. cus its a straight swap and whilst there there they might aswell plop it in. infact. flop it. ill have the camshaft and cambelt done, with a head gaskket and skim done all at the same time with the GT camshaft. does anybody know were i could have it alll done and a price??
  • Replies 15
  • Views 1.7k
Can you not do it yourself?
Its really simple and a skim on its own only costs 20 quid a an engineering workshop.
Save youself lots of dosh.
You'll be lucky to get all that work done for less than 400 not inc cost of camshaft.
Head gasket is around 35 quid VAG
Cambelt kit is 40 quid.
I have a cambelt timing kit for you to borrow for free if you leave me a full deposit. I live in leics.
you will need new headbolts too, 30 GBP VAG
Edited by smillsey
well. i cant do it myself. i dont know how to. I'm not that good with enginees. i know the basics but i dont dare take half my enginee apart or touch owt that could properly damage it lol. thats nie of you mate ill see. ill go buy all the parts this weekend i reckon. if i get a waterpump, cambelt, headbolts camshaft(if i have that done) and headgasket new rubber seal for the rocker cover. and i have a polished rocker cover ill have put on instead of the old one. wont need much more will i?
can anyone do it for me to save me a lot of dosh and earn yourselfs some dosh ???
Edited by Hardcore
Get it to me and I'd do it for some booze lol
would you really?
how much would you want for it mate? how long would you need the car for??
are you confident that you could do it?
giv me your postcode lol and ill see how far away you are:)
heres a list of everything which ill have done from you lol and you sort a price and time you need the car for out for me:
-new head gasket.
-skimmed(if you can if not ill get that done after by a garage properly)
-GT camshaft fitted (Straight swap for the old one)
-new cambelt fitted with the GT pulley.
-put the chrome rocker cover on, ill get a new rubber seal with it too.
-new water pump fitted
-new oil breather pipe(straight pull the old one off an stick a new one on lol 5 min job)
then when i get it home ill give it an enginee flush, and oil and filter change and put sum decent oil in it :)
should make my car run stronger, cleaner and so on. i think my head gasket has gone, but myt aswell fit the otherstuff whilst were changing it and get a few things done. cus I'm gona ask this guy to turbo it for me 2 :| so all these little things help strenghten int up a little.
Edited by Hardcore
Yeah I would and I could do it, the problem is when you check my postcode:
AB53 6TL
:lol:
hahahahahaha. thats like a 9 hour drive!!
crazzyyyyyyyyyyy.
well. seriously now. in 3 weeks i get 4 days off. friday till munday. go back wrk on tuesday. so if i came up friday night. would 4 days b long enuf an would you want to work through your bank holliday. and how much lol.
...and are you bien seriouse lol?
I work Saturdays... But yeah I would be up for doing it, would only be a couple of hours work, just need to find somewhere to skim the head if you need that done - however I see a problem here. Or more to the point, I don't?
How come you are changing the head gasket, if it doesn't need it?
cus i think it needs it. theres yellow gnunk in my oil. so water is geting in sumwere. and my waater was on the low line the other day after 2 weeks off driving.. head gasket gone no? eiva way. tis worth having it done if i m turbo'in it. jus to keep it secure :)
i did mine myself cause i snapped my cambelt at 80 was really easy ,
u'll need the
head gasket
new bolts
cambelt kit
waterpump
i did it all myself but burrowed the tools and a mate whos a VW mechanic helped but only cause he had he tool to remove and re fit the head
plus i needed 8 new valves and a re surface , gave it to a place called head technique in telford and they did the work including fitting the valves and new cam oil seals for £125
nice one. thanks for all your help guys!! iv found a guy whos local who can do it all for me. all i need now is the cambelt kit cus i can buy the other parts myself.
I just thought it was odd that you wanted it done but were prepared to drive for 9+ hours :lol:
You'll need more than just a new head gasket if you are turboing it too.
Glad you've found someone slightly more local though!
what more you reckon i should need mate?
Low comp pistons and uprated rods, those Mk4 Polo 1.4s are a bit chocolatey with regards to boost or so I hear. A spacer plate and/or two head gaskets might be enough but it will only get the compression down, you won't want to be boosting too hard, due to the next weak point of standard pistons and rods.
welll. that s the difficult part. got no ide were i can buy pistons from lol. and guessing there gona be expencive.
