Custom sub box idea
well after a failed attempt at making a fibreglass enclosure for my subs.
i'm thinking of making a couple of new boxes or modding my own, to make them fit in the space between the rear struts and cluster (MK3)
So this is the design, basically a standard sub box with two corners cut off and sealed up!
therefore
If i make it, i can sell my 2 sub boxes (maybe subs as well and get a pair of 10")
or mod my boxes and keep the 12" pair
any suggestions on what i should do?
  • Replies 26
  • Views 4.6k
read this, make two and enjoy good SQ?
http://www.talkaudio.co.uk/vbb/showthread.php?t=76606
that was the guide i was trying, got half way through, looked crap and i had way too much glass fibres in my fingers (had gloves on as well). so got pissed off and binned it!!!
But i did manage to make 6x9 pockets from glass fibre for my parcel shelf (which i still need to finish)
i want to got for a solid construction
pay someone else to build it for u?
lm audio in knebworth
or source sounds in sheffield
there was a company that used to make enclosures that fitted in that exact space. they were pretty expensive though
i've decided on a fat piece of MDF to hold the speaker, and have a box enclosure on the rear.
since the subs need a sealed box with 35L of air space. the box should be 35Wx40Lx25D
tell a lie, its 30L
so 40cm(W)x40cm(L)x20cm(D)
why do you want them sealed outa curiousity?
sound much better ported ;)
Mike why do you have a picture of PhilJ as your avatar?
currently i'm running 2 12" subs, one ported one sealed, and i think the sealed give a better sound.
Philj is a pixelated fat italian american plumber?
i must meet this fellow!
well keep both :)
i personally like massive tuned ported boxes
keep both?
i want shot of the two boxes in the middle of my boot, to make a custom boot build with 10".
this will give me more of a puncher sound, which is what i'm after.
so should i port or keep sealed as i was gonna do?
well if you want punch, i assume you play dance type of music so sealed
where as ported will give a nice deep bassline.
dance music - no no no
I'm a metal head - but i'm a drummer/bassist at heart and prefer punchy bass rather than flat out ass grinding bass!!!!
sealed then.
I might have a go at making one of those boxes as i'm making do at the mo running 1 12" sub thats in a twin box, with the other sub not wired in! Too poor to buy a new one!
This is proving to be more difficult to plan than i thought it would be.
using the above design, i can get about 20L internal area! and that would kinda be a snug fit!
using an 'L' shaped box would give me less, about 12L.
This is me working on a depth of 20cm though, don't think i can get anything larger to fit in and remain flush with the edge of the strut housing
ah ha
using the above design with a 25cm depth will give me about a 30L internal area.
Let the constuction begin!!!
well after a failed attempt to make a solid box (to many cuts and holes to give me the internal area i need)
i've gone for a fibre glass back to it! (yeah will-antirocks suggestion in the first place)
but this time, i've just the fibre glass paste.
Before (but after masking off the area)
first layer
just need to let this set then do another layer and i should be good to go!
  • 5 months later...
dragging up an old thread here but this project has been on the back burners for too long, so an hour yesterday and a couple this morning i carried on with it!!
Well i've chopped some of the fibre glass and reshaped it to fit better.
so close to finishing now i can smell it!
this is only the first one, got the other side to do after this :-D
been thinking of doing this myself in a few monthes time see what yours turns out like first though lol
nice, weird about teh vibroglass being HOT though... good luck with it 8-)
yeah the last fibreglass section heated itself up!
very strange :?
hit abit of a wall, wiring!
i've got a pair of connection plates but where should i put them?
connector plate is on
decided to put it ontop so its easily accessable!
Next problem, how can i secure it in the boot?
velcro?, stuck to the box and inner arch respectivley?
Means you can pull it out if needs be too?
