13x7 et5 on a breadvan?
Hi all
Having a few dilemmas finding some wheels that will go under the arches on me new daily 86 Polo breadvan.
I will be running a PhilJ 80/60 lowering kit and have also ordered some camber shims and the g-ladersite adjustable top mounts, so will have plenty of camber to play with!
I did consider these & sourced some at £20 a corner, but they are a perculiar shape inside and will not clear the front brake set up without spacing and adding berg cup arches!
14x7 Lotus Eclat wheels
I have found another set of wheels i like that are 13x7, 4x100 with an et of 5mm, will these go if i run a stretch tyre of 165 55 13?
Thanks in advance
Alex
  • Views 1.7k
could you let me know where i can get those wheels? and the pcd?
PCD is 4x114 Lotus fitment, i asked a lot of people but nobody knows the offset iam afraid, not sure about giving my sources away just yet as i may still have a go at fitting them!
Alex
if the pcd is 4x114 they won't fit a polo
and the only way you will get 13x7's with an et5 on a breadvan is by doing this........
