Removing and replacing a 6n wing?
Hi I need to remove and replace a 6n wing could someone advise me on the procedure?
Do the bumpers need to come off?
Is the wing welded, bolted or sealed on or a combination of these?
Cheers,
Mahbs
  • Views 1.7k
the wings are bolted and sealed a bit, you can get away without removing the front bumper, just the headlight and arch liner
tis a bit of a fiddle :D
Like Foxie said, tis a bit tight but i managed it so I'm sure anyone can!
Thanks for the speedy response.
Any specialist tools required or just a basic socket set?
Also what sort of sealant is used? Is it like the stuff you use to attach spoilers or some other type?
Cheers,
Mahbs
nah its just siliconey stuff if i remember..should just wiggle off, will probably be more stuck by the amount of shit collected around it over the years
wheel off.. 4 bolts
inner arch out.. 6bolts 2nuts
grill out.. clips in
bumper.. 2bolts on top.. 4bolts behind lower grills (leave loose)
lights out.. 2on top.. 1bolt bottom front
wing
4bolts under bonnet down wing 1bolt at bottom
2bolts under wing door side
2bolts behind the bumper
...think thats it!
not sure where u are but if u near me n got the tools n needa hand give me a shout.
david.
Edited by riskie
... will probably be more stuck by the amount of shit collected around it over the years
Yep probably right on that :lol:
wheel off.. 4 bolts
wing
...think thats it!
david.
Cheers David and everyone else sounds like a job I can do to keep costs down.
Mahbs
sure is.. just take you time. took mine off n had them painted bout a week ago then put back on to keep the costs down. ;)
was done in the paintshop so all tools were there for me.
got to pickup some recaros tomorrow mornin from london but free in the afternoon if u near me.
david.
