TOOLS FOR BODY WORK!:!:!
Ok i picking up a welder in couple days because I'm going to do a few body work jobs, you know smoothing and removing!!
basicly just wanna know what else i need for the job, i will have a welder so what else do i need?
cheers peeps!
  • Replies 13
  • Views 2.1k
plod, sanding blocks, plates to weld into whatever your smoothing, errrrrr, dunno what else. I ain't no bodywork expert!
Selection of hammers. Small ones for shaping, large one for when things go wrong.
depends what you want to do a compressor and air tools are very handy but there are hundreds of things you could use in a bodyshop
If your going to weld things and smooth them then you will need an angle grinder to grind the welds down before smoothing.
ahh angle grinder!! def need one them!! well to be honist most stuff has been done but i wanna smooth off the tow bars and also have the tools for future cars!!! :ninja:
i got loada air tools use them at my work!! is any perticular sandpaper required to sand filler??
for filler i'd get 80, 120, 180, 400, 1500, 2000 so you can sand primer and paint too :)
I find with an angle grinder use flap discs, you get various grades. I personally have found them better than the usual metal grinding discs. The other thing that I have found for more precise grinding is a dremel(mines a cheaper clark version) with the small cutting discs. If your careful they can precisely grind/even cut areas that you can't get into with the angle grinder. They brake very easily though so buy a pack.
Mind you with air tools you get a small cut off tool anyway that takes discs..
cool cool!! cheers guys! btw ruffly how long does filler take to dry so i could drive it?!?! also one other thing is under where the bumpers and the paint work is all ripperly would i just sand that down to get it smooth?!?! i been told it celler or sumin and is a bitch to get rid off!!!!
use a hot air gun over the filler will be dry in 10 mins if it's not put on too thivk
no idea what your going on about riples ?
the ripply part could be underseal underneath your paint?
The ripply part is the underseal to protect from damp and stone chips. If you're gona strip the underseal and that then I guess you're painting it yourself? In which case you need a good sized and well ventilated garage, if you're gona strip the underseal you wont want to leave it in the rain either until its sealed again!
My suggestions: lots of sockets, breaker bar, spanners, screwdrivers, overalls/boiler suit, hacksaw (bolts will seize ridiculously tight on suspension), a garage, lots of coffee to keep you warm, and a good handwash (Swarfega)...
Dremels are wicked tools :thumbsup:
But yeah, I'm doing all this on a evening course at college.
Welder, Grinder, orbital sander, lots of different sand paper, lots of different discs, decent sanding block and everything else other people have mentioned above.
A dent removing hammer kit is also worth having, metal will bend if u make a mistake with the welder and filler isn't the way to hide it.
It will say on the tub how long you need to leave it to dry (filler).. teachers at college advised me not to use a heat gun on filler as it cracks if it dries too quickly.
I'm going to remove the front and rear tow bars. fill the hole for the wiper as i have singal wiper kit! and the lil resess on the n/s for i guess left hand drive motors!
bassicly with the "ripply" bit i think is sealer i want it to be smoooooooooth!! so i thought could just sand is back not remove it!?!?!
i have sockets all theat lot, and a garage (thanks to work :-D)
