Almost finishing my Gt
ok i am hope fully finishing my Gt engine and i have set a target to finish it by the 18th of may, which is run what you brung day at santa pod.
the gt engine will have had
full engine rebuild
head skimmed-slightly more compression
shrick cam 268/268
4-2-1 manifold- with decat
bike carbs with individual induction kits
centre section removed on exhaust to standard backbox-may be de-baffled unsure.
all this will be running in a mk2 breadvan, not stripped out.
so a 1/4 mile, i am hopeing just under the 17 second mark, i think thats reasonable, any one run there Gt with a few of these mods?
also are mk2 breadvans lighter than mk3 coupes or not?
warren
  • Replies 17
  • Views 1.6k
i dunno abpout the time but yeh breadvans are 5kgs lighter then a coupe !!
Guessing your ability to drive will have a big play in it.
I'm sure there'd be a big difference in time (using the same car) between someone like me whos never run a 1/4 mile and someone like Yoof who has done it a billion times.
i will do a whole day, so from 9am-9pm unlimated runs so i guess i will have a fair bit of practice, i am a novice but know how to drive. i just hope the engine will be run in buy then, i am going to have to clock about 1000 miles in a month.
You should hopefully see 100Bhp+ dont know what 1/4 time that will equate too ..
skimming the head doesnt increase compression on them as the CC's are in the pistons. Should easily get into mid to low 16's with a good setup and decent tyres.
Please explain /\/\/\/\/\
always thought they by removing material off the head you create a smaller space for the piston to compress the air and fuel in.
if the pistones got the same stroke and is the same size as a normal piston then you'll have increased compression?
maybe not :S
somewhere in 16's would be my aim with that set up
well by my rubbish estimations and using the tool below i reckon you could do a 16.31 !!
http://www.torquecars.com/tools/quarter-mile-time.php
Yeah but it says i will do a 1/4 mile at 13.85 seconds!! I very much doubt that!
maybe not :S
Not if the head is essentially flat to begin with!
Find some traction and maybe it's possible :lol:
Don't forget to add the weight of the driver onto the G40s 830kg kerb weight. So 170 bhp G40s will take 14.09 seconds with me in the car according to that lol!
yeh u should see a 16flat or slightly below depending on your driving style.
my old gt that was stripped (no bonnet either, haha, catch problems...) that had twins and a highly ported and polished head ran a 16.4 on brand new tyres.
also if its an unlimited day at some where like the pod or the place in essex (name escapes me) you may find you dont get as many runs as youd hope because everyone rocks up to have a go.
sounds like under 17 is going to happen then. cheers for all the help, yer i know what you mean about not getting as many goes as hoped i will see and take a vid or something and post it up, i may strip the back out for it the. i will still run it with my roof rack on.
maybe not :S
This is what i always thought, it would increase compression in say a pinto engine where the head isn't flat?
unless u go at it in reverse you shouldnt be seeing any 17's dude
if your gonna bother stripping the rear leave the rack at home. an it sounds pretty obvious but practice at as many traffic lights as u can too.
when u planing on going?
18th of may is the date i have set. i think i will leave the roof rack at home, i will never thought about the lights i dont even know the sequence on a quarter mile
