Seat problem :(
I sat in my driver seat last night and the left hand side decided it was going to drop, (hard to explain) its as if a bolt has come loose and now the left side leans further back than the right. I've looked everywhere and I cant find where anything seems to be different to the other side. Has this happened to anyone else? If so can you suggest where to look and what the problem was.
Evo
  • Views 930
Happened to me once years ago but the car died of something else before I got around to sorting it. You know when you alter the rake angle of the back of the seat, there's a some kind of ratchet arrangement at work to set the angle. My best guess at what had happened was that this had slipped on one side. The cure would be to take the seat out remove that mechanism and either repair or replace it with one from a scrappy. Please don't take this as gospel 'cos I never did it myself, but it's a possibility. Good luck!
Edited by labougie
Thanks, think ill take the seat out at the weekend and have a see what i can do
could also be the plastic insert that goes into the runner on both sides, on my last polo the one on the right was missing and the dirvers seat wobbled a bit, might be worth having a look
