Mk3 Polo Owners
I am sure alot of you Mk3 owners will be aware of your cars sitting slightly lower on one corner than the others on most cars .
Another post on the forum has made someone aware that the reason for this may be the distance between front and rear wheels .
When i measured the distance between front and rear wheels i found a diffrence between the passanger and drivers side of the car ..
Unfotinatly i dont have measurements now as the car has been sold on .
I rectified the problem by grinding down part of the ARB .
What are the measurements on either sides of your guys polo's ??
Centre of wheel to Centre of wheel
  • Views 962
My car doesn't have wheels... sigh.
my gt seems pretty level. my g40 on the other hand looks a bit lop sided, but then it is sat on its bumpstops which could use changing as they have gone a bit flakey
i always thought it was because the car was designed for left hand drive.
Fuel tank was placed on the right to counter balance the weight of the driver.
but since we're RHD, we're both on the same side!
