Sunroof going into Mk2 saloon
Right - Just bought a sunroof off eBay, Item No.310005467813 . First off, if anyone knows anything disastrous about Topline sunroofs or the T800, please let me know!!!! Second, I've had a set of Ranger roofbars for ages and this would seem as good an excuse as any to put them on. Can you guys walk through the fittings with me and see if it makes sense? They look like this:
Along the bottom, the parts for one bar end, top left a loosely assembled version and top centre, the two main fixings. The bigger machine screw is locked into the bar end by a grub screw in the bar itself which locates into the flat on the machine screw. Next comes the rubber. It would seem as though next comes the roof, with a hole just big enough to allow the nut on top of the next fitting (dunno what to call it - widget?) to come through the roof (so that all the tightening up gets done from the outside) leaving the shoulder on the widget pressed up against the roof from the inside. The smaller machine screw goes up inside the other end of the widget and is presumably to lock the bigger machine screw in place once it's tightened up.
The widget has a flat along its length, as does the the widget's shoulder. If there were a box section inside the roof, right at the edge, then it would make sense for the widget to be as long as it is, and to have a flat on it - you'd drill a hole through the box section for the widget to sit in. It's a strange system though - if I've described it correctly, the widget isn't being held up by anything. A third hand would need to hold the shoulder against the inside of the roof while you gripped the nut part from the outside and screwed the big machine screw down into it. How far down to take the machine screw would have to be trial and error, as you wouldn't be able to adjust it with the bar on. It seems a bit weird - does anyone else have another take on it? Thanks.
  • Replies 15
  • Views 3.1k
Does your classic already have a sunroof? or are you cutting a hole?
Cutting a hole :?
please dont!
please dont!
Gotta be done! There is a sunroof-shaped hole in my life! The factory sliding steel one on my last Polo was such a delight and I've been all round the houses to try to retrofit one of those but it can't be done. The factory fitting isn't just a hole in the roof, it's a well for the moving section to butt against so that's out. You can't even unpick the roof skin complete and replace it with a sunroof one 'cos the saloon roof is a different shape at the rear end and it would mean a butt or lap joint - impossible to get right. I know what you're saying - it is somewhat sacrilegious but damn it - I need my open air!
NO!!!!! Please don't!
Aftermarket chopped in sunroofs are DISGUSTING!
Admittedly, I like the fact I can look up into the sky in my loon, but honestly, the horribly aftermarket seal, the cringeworthy 'moonroof's' sticker, it's not worth it!!!
Tintop ForTheWin!!!
*disclaimer: it's your car do what you want blah blah blah....
Does it really look that bad?
YOUR loon has an aftermarket sunroof (he said, accusingly!)
I believe steve 86c fitted a sliding roof to a non sliding roof car once. You have to weld in the extra layer of roof that the sunroof resides in. No need to replace the whole thing!
OK guys, forget about the fixings and how they work - they're specific to the Ranger. Because the Ranger roof is longer and the bars sit further back than they would do on a saloon, the mounting points are in the B and C pillars. (Thanks Gaz!)
I'm thinking the best way to tackle it would be (since I don't need the bars to carry any weight) to mark and drill, then shape up a metal plate (3" x 2" or bigger if you could get it in there) and sit it up against the inside of the roof on a pad of Isopon to spread the load over a reasonably wide area. You'd gain a bit of strength by putting it as close as possible to the roof edge fold as well. Then put the requisite flat into a length of threaded rod to lock into the bar and simply bolt up from inside. Plus loadsa silicone.
That would be bloody perfect - I've pm'd him.
Edited by labougie
I've got a bloody ford one on mine sorry poor pic, don't know when or who would of fitted it. It looks ok, doesn't leak and you can take the whole glass out. I'm sure i'll enjoy having it when the sun comes out but I would still rather roll without.
yeah our bread has the aftermarket pop up glass one...id rather it didnt , but its good for ventilation in the summer
I know :lol: :lol: :lol:
To be honest mate they're not that bad, I didnt realise it was a steel sliding one you're on about. They're pretty damn cool actually. I just don't really like the aftermarket pop-up glass ones.
PM'd back.
Haven't done a sunroof graft yet, just a total roof graft.
I have the parts of a Mk.3 Passat to fit, but lack the time I need to do it :-(
I fitted an aftermarket sunroof to my breadvan with my dad, seemed like a good idea at the time and I dont regret it. The roof was all fucked anyway from where people jumped up and down on it.
I'd like to fit a tilt and slide or similar maybe even open air that would be sick. Let us know how you get on labougie. Is your loon the matt black one?? Cos it pimps if it is 8-) :cool:
that mk1 golf at UD with the open air roof was siiiick. :)
