Polo mk5 se 16v
Am just wondering what kind of fault should i be looking for?
Am going on sunday to have look at one and hopefully come home with it! :-)
Carl
  • Replies 8
  • Views 1.4k
Carl
cacked up throttle body (as per usual).
excessive fuel consumption can *apparently* mean ecu fault (never found that with mine)
brakes will be spongeyer than another car, 6n2 polo renowned for it, bigger brakes apparently solve this.
rust round rear arches, bottom of front arch/sill panel.
rear boot handle/lock holds water and rusts well
err thinks thats it without explaining "the usuals"
cheers mate
what about gearbox faults like the 6n 16v polo and gti?
gearbox knocks/ whines make sure it selects all gear accordingly
check all electrics too fella
so similar fault as a mk4 16v?
similar to checking any car i suppose! 8-)
true!! should be going tomorrow to have a look!!
cheers
On mk5 polos the whole body is galvanised so there shouldn't be a spec of rust anywhere, if there is leave it alone it probably been in an accident!
dodgy windows(sometimes mine work, sometimes they dont)
