Whats this do?
here
Item no: 270218389460
Whilst browsing through ebay.de I came across this? Whats it do?
Edited by MrP
  • Replies 37
  • Views 16.4k
link doest work
i translated it to:
Hy, sells here a wishbone prop for a Polo II 86c. The prop at series fastening spots arm da scat man, installed dh. none to bore of holes necessarily. It has at the lower surface schleifspuren von poopin mouth of to take up. There private sales no warranty or cancelling possible!!! Much fun when offering
think its a bizare track control arm upper mount thing? cant see it doing much...
i translated it to:
LMAO :lol::lol:
Yeah, thats what i thought? But where does it fasten too?
I was thinking inbetween the two TCA's on the rear.. Kinda in the same position as that bracket under the CAT?
Looks to me like a lower strut brace... :-D
Yeah, it does.. but how do they fit?
it bolts between the two points on the body where the bottom arms mount to
^^^ what he said! doesnt work well on lowered cars though due to a lack of ground clearance. I've got a wiechers one, had to take it off coz it kept bottoming out
Right.. so a big waste of time then? Or could you tell the difference with it fitted?
i really cant see that doing anything at all!!!!
and i said in my first post where it was for and where it mounts lol
Tightens the front up alot. You will notice a difference as the polo suspension set up is possibly the worst ever! :lol:
how can it tighten the front end up tho? they way it mounts, where it mounts, how it mounts, i can think of much better upgrades, i cant see that making any differences at all
Here's one fitted to my old G
Here it is less than two miles later lol
you can however get one from wiechers with a cut out for the exhaust and this improves clearance greatly.
i have to admit i didnt notice much difference with mine fitted
It reduces the amout of flex of the body between the two bottom arm mounting points and therefore keeping the suspension geometry more stable during cornering. As the shell is not very rigid at all, the bracing contributes alot.
And yes of course there are better modifications but theres always going to be something better!
well until you end up with the equivalant of an F1 car with no restrictions!
in theory it should, but that item in particular will do jack jones, its mounted at just one side of the track control arm, infact i will go so far as to say that is a usless item, chocolate ash tray
I'm not going to explain anymore, you quite clearly don't understand chassis dynamics or how a srut brace works. (or the temperature of ash from a cigarette :lol: )
Edited by coupegts75
Just buy a PPP subframe...brace-tasttic :lol:
For those not wanting to go to a full subframe & wishbone set-up, we've got something for you!
Pictures will be put up tomorrow 8-)
Yoof
shameless plug lol
you have just proved you "quite clearly" dont know shit all either, a frame, bolted to one side of a track control arm, is gunna work
I'm not saying strutt braces dont work, I'm saying this brace wont do fuck all
get a grip cocknose
You better get on the phone to the likes of porsche and ferrari and tell them that youv'e actually discovered chassis rigidity does not affect vehicle handling whatsover and they are wasting their time. :disgust:
On the early polos the position of the TCA mounting points on the body move relative to each other due to twisting and bending of the body during cornerning!...... FACT!
Moving of the points where TCA's mount affects suspension geometry! ....FACT
Changing the suspension geometry during cornering has detrimental affects on the vehicles handling! ... FACT
Mounting a brace between these two points means that for the position of the TCA mounting points to move they have to first bend or twist this brace!... FACT
So for the same amount of force exerted the body due to cornering , if an extra piece of tubular section steel has to be subject to bending or torsion the points at either end of this 'lower strut brace' will move less relative to each other! FACT
Now how does this 'lower strut brace' not have any affect whatsoever to the dynamics of the vehicle??????
what the hell are you on about?
all of those facts are correct, well done
but you seem to be missing the whole point while you babble your overpowering knowledge
put the book down, take your glasses off, i will make it simpler with no words to confuse you
that strutt brace (that meaning the original one in the first post), will do very little if not nothing on a polo mk3, as it is mounted on one side of the track control arm
so just to follow up, I'm not saying no brace works, or that porsche and ferrari are wrong in what they do
Its really hard to communicate on here sometimes, i mean read back my posts i did make it all very clear?
The one in the first post is the same as the one that greg posted a photo of it fitted to his car!
