removing the bump strips off my doors
i want to remove the bump strips off my doors but dont want to do it if it reveals some nasty pin holes
are they glued or pinned on the mk4 6n??
  • Replies 12
  • Views 1.8k
You could've searched this issue and founds lots of solutions but anyway, don't worry. The strips are ONLY glued so try heating them up and them removing. All the glue left on the car can be removed using mehtanol spirit on a rag or tar remover.
cheers pal :thumbsup:
hmm is there a sticky for this maybe when u do it make a kinda how to guide so people can link to it when it gets asked in the future?
ye tht can be done! il post it on when I've done them
make sure you post it in the technical section, being a technical question and all that...
Methanol spirit eh?
so what would you heat them up with a heat gun???
carefully obviously!
I'm also interested in dong this
Hair dryer will do
Hot water
I used a hair dryer and a credit card and some care
All the above methods will work but will take you an eternity and leave your fingers sore.
Best thing to do is go into a motor factor and ask them for a caramel/fudge wheel and they should know what you mean if they stock it. Its basically a wheel that looks like caramel/fudge and smells like it (doesn't taste like it thoug :(). You basically attach it to a drill and it removes any sticky crap without damaging the paint.
Takes 10 mins in total to do. The wheel should cost you around a fiver. Maybe a bit more or less depending on the shop. Halfords and Motorworld don't stock them for some reason. I think somewhere that deals more with bodywork stuff would be your best bet.
Personally i haven't done my side strips yet, but its the same concept as debadging the back.
Hairdryer and/or hot water(not boiling) to soften and loosen the glue. Be careful to drop the water near the hairdryer or you will be in for a shock (literally). getly push a credit card behind, all the time using gentle force to loosen the plastic. Eventually it should just come off...
There will be shit left behind....get the bulk of the glue off before using tar remover. Any tar remover will do, do not rub too hard your paintwork should be fine. finish off with a light t-cut or polish.
rick
IT took me ages to get rid of all the glue behind my strips, used tar and bug remover, a heat gun and numerous credit cards (kept melting them lol) i ended up rubbing the last little bits of glue with my finger and now have a flippin blister lol
.... BUT its well worth it, they look crap with them on IMO
