de wipering mk 4hi guys
i wanna take my rear wiper off my mk4 but i cant find the bungs that cover the hole on ebay
does anyone know where i can get 1 from or what the proper name of them is?
cheers ben
  • Replies 13
  • Views 1.9k
Halfords do just general sized blanks, or and someone will help by reminding me of the website that has proper blanks, but charge massive scene tax at like £25 + p&p
Or just make your own! Super glue a coin over the blank with a hole in it, skim fill it etc, spray and refit! :D
ideally you want one of the plastic shaped ones,,,i got mine from 2modified for about £20,,,theres also a custom mat place that do em,,justmatz or something...thats mine\/
any 1 else?
ben
justmatz do them, or get a grommet or similar to block the hole.
What size is the hole?
I got 25mm gromit's from halford's, 3 for 89p, mine is a 6n2 but i assume it will be the same size.
anyone elseknwo where to get 1 frm?
cheers be
What I did was put a bolt with a round head through it and put a nut on the end (inside) then paint the bolt head black. Blanked it off and kept the plastic bit already there in place without sticking it down.
I removed the rear wiper from my 6n last week and filled the hole in with a grommet from halfords. Got 3 for £1.50 i think and the biggest size fitted perfectly. Hope that helps.
how do you remove the actual wiper and motor?
Remove the wiper arm (13mm nut), remove the motor nut (22mm nut), remove the phillips screw from inside the interior boot trim handle, pull the trim off, starting at the top. Unplug the motor, remove the wasjer jet pipe, undo the two outer 10mm bolts and pull the wiper motor out!
thanks i'll give it a go 2moz 8-)
wrang justmatz today and they do the proper fitting one for 18 quid delivered so gunna get 1 from them
thanks for your help guys
ben
